Results 1 to 6 of 6
Thread: ► APEX | Fully Forged Lightweight BMW Wheels - Our Strongest Ever
    California BAY AREA
    e30 M3, 335d
    Questions?
    Call: 925-245-0773
    Email: expert@apexraceparts.com
    Web: www.apexraceparts.com
    Hours: M-F 9a-5p PST
    ARC-8R & EC-7R
    Everything you love about the original, now enhanced with all the added benefits of forged manufacturing.
    ➡︎ Significantly increased strength
    ➡︎ Improved brake clearance
    ➡︎ Paintless knurled beads
    ➡︎ New premium finishes
    Order Now
    ARC-8R / EC-7R
    Available Finishes
    Specifications
    APEX ARC-8R Forged Wheels - YouTube
    APEX EC-7R Forged Wheels - YouTube
    Even More Strength
    “Forged” doesn’t mean strong. Many forged wheels focus on weight reduction so much that they end up with the same load rating as cast wheels. Think all forged wheels are stronger than cast or flow formed? Think again. We've added up to 1,000 pounds of extra load capacity per vehicle compared to our flow formed line.
    Learn more about why not all 'forged' wheels are strong.
    Better Brake Clearance
    The flow formed ARC-8 was our first design, so it features our older barrel profile with compromised brake clearance. Typical blank forgings (the starting point many other manufacturers use) can have even worse clearance than our original flow formed wheel. By developing our own proprietary new profiles and new dies, the 18" ARC-8R and EC-7R can clear Brembo 380mm kits and the 19" version can clear BMW 410mm carbon ceramics.
    Learn more about why we had to create our own new forging dies to clear big brakes.
    Paintless Knurled Beads
    Not all knurling is created equal. To reduce unwanted tire spin as much as we could, we protected our knurling from paint to keep them sharp. We didn’t take the cheaper shortcut of painting over the bead area, which makes the knurling smoother and rounder. See and feel the difference.
    Learn more about why our forged wheels have unpainted knurled beads.
    New Premium Finishes
    Our forged wheel line enabled us to release premium finishes we’ve always hoped for. Fully polished aluminum and hand brushed with tinted clear now join a wide range of painted finishes, with more to come. Our forged wheels not only deliver performance, but also provide distinctive new styling as well.
    Tailored Fit, Right Off-The-Shelf
    APEX is known for stocking a wide variety of chassis specific fitments to meet the needs of a very diverse enthusiast community. We’re releasing those same street, track and race proven fitments and more in our new forged line. New lower production requirements allow us to cater to even the most niche segments of the BMW market that may have previously been off limits.
    Weight Optimized
    We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a fully forged wheel with an ideal balance of strength and weight.
    JWL & VIA - More Than Just a Stamp
    Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. APEX wheels get officially tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our new forged wheels exceed those ratings by almost 20%. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy.
    Learn more about VIA and JWL
    Additional Features
    Hub Centric - All APEX BMW wheels with a 5x120mm bolt pattern are purpose built featuring a 72.56mm center bore. No centering rings required.
    Center Caps - We don't charge extra for caps and we design our BMW wheels to be interchangeable with the OE roundel cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps.
    Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly.
    TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes.
    Lifetime Warranty
    All our forged wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase.
    APEX360 Wheel Replacement Program
    Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
    Our unique APEX360 Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices.
    [center]Learn more
    Order Now
    ARC-8R / EC-7R
    Fitment Guides
    We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides.
    APEX Forged Wheel Gallery
    Wheel & Tire Packages"
    Shop Tires
    For your convenience, wheel and tire packages are now available at APEX. Our knowledgeable BMW Product Experts hand pick some of the best compounds available from prominent brands like Michelin and Nitto, and we’ve priced them competitively.
    All wheel and tire packages include free mounting and road force balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse.
    Order Now
    ARC-8R / EC-7R
    Questions?
    Call: 925-245-0773
    Introducing the ARC-8R
    Introducing the APEX ARC-8R Forged Wheel - YouTube
    Race Silver
    Anthracite
    Satin Black
    Brushed Clear
    Polished
    Introducing the EC-7R
    Introducing the APEX EC-7R Forged Wheel - YouTube
    Race Silver
    Anthracite
    Satin Black
    Brushed Clear
    Polished
    California BAY AREA
    e30 M3, 335d
    New and improved: A classic returns!
    Our highly popular ARC-8 design recreated as the new forged ARC-8R.
    Sep 2018
    Portland
    2011 X6M / 2015 X5 35D
    I have your sm-10 square setup 18x9 on my E39 M5.
    Love love love how these wheels look and feel on the road!
    Sent from my SM-N975U1 using Tapatalk
    California BAY AREA
    e30 M3, 335d
    APEX Forged: Stronger than ever and ready to ship.
    Our new forged offerings have significantly higher load ratings with over 1000 LBS of additional capacity for 4 wheels in an 18" diameter compared to our already strong flow-formed wheels! The increase in load rating allows these new wheels to better cope with the demands that sticky tires, heavy cars, and high downforce present.
    E36 or E46? Either way our EC-7Rs are a perfect fit.
    Specs:
    E46 M3 18" Wheel setup:
    189.5″ ET35 EC-7R Forged Wheels in Brushed Clear
    275/35-18 Toyo Proxes R888R Tires
    E36 M3 17" Wheel setup:
    17x9.5" ET35 EC-7R Forged Wheels in Polished (square)
    245/40-18 Kumho Ecsta V720 Tires
    APEX 12mm Front Spacers
    Quote Originally Posted by JacksX6M View Post
    Looking good!
    Are you running modified hubs on your E39 or did you have the center bore enlarged to fit these wheels?
    -Tom
    Sep 2018
    Portland
    Quote Originally Posted by Eddy@ApexRaceParts View Post
    [Center]APEX Forged: Stronger than ever and ready to ship.
    Looking good!
    -Tom
    I was running Turner motorsports 74.1 to 72.56mm huncentric adapters.
    California BAY AREA
    e30 M3, 335d
    Understood, good to know!
    -Tom on behalf of Eddy
  1. ► APEX | Redesigned & Re-engineered BMW Wheel Spacers
    By Eddy@ApexRaceParts in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 05-19-2020, 05:59 PM
  2. ► APEX | Redesigned & Re-engineered BMW Wheel Spacers
    By Eddy@ApexRaceParts in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-13-2020, 07:35 PM
  3. ► APEX | SM-10 Lightweight Track Wheels
    Last Post: 12-17-2019, 04:04 PM
  4. ► APEX | FL-5 Lightweight Track Wheels
    Last Post: 12-12-2019, 05:11 PM
  5. M-Double spoke polished forged ltwt BMW M3 wheels
    By paul e in forum BMW Parts For Sale sponsored by Bavarian Auto Recycling
    Last Post: 03-18-2002, 12:07 PM
