Results 1 to 5 of 5
Thread: APEX ARC 8 ET30 offset fitment
    Sun Prairie, WI
    99 M3
    Hello all,
    I am sure I am asking the same question that someone else has but I wanted to see anyway. I recently purchased ARC 8 with ET 30 17X9 for my E36 and was hoping that I could use these as my track wheels. As of now my biggest issue is that I have ST40 Stoptech BBK on and can not clear the calipers with this. I know I would need to run a spacer to clear the brakes. I think I would have to go up to a 15mm spacer to clear the caliper, but then I would be pushing the wheel out even more so I'm not sure about clearance issues on the fender. I do not have a problem putting flares on or a huge pull on the fenders. I am running MCS suspension but I think that is not an issue with the rims I have. Should I just sell the ARC 8 ET30 and just get the ARC 8 ET 42 that will fit over the brake and just be done with it?
    Thanks for any and all opinons
    Michael
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Get some Amazon spacers and check clearance?
    I run 17x9.5 +35 with a 15mm front spacer to clear the perches on my MCS and I have no outside rubbing up front. That being said, my fenders are rolled.
    ithaca Ny
    95m3/97m345/powerstroke
    Dont know what size tire you plan to run but you should be fine with a 245 and the 15mil spacer, as long as you have -3 or more front camber. 245 street tire that is.
    Sun Prairie, WI
    99 M3
    So a 15mm spacer isn’t too much on these cars then? Thanks for putting my mind as ease. I was worried about having the wrong size. Glad I can use the concave wheel (I really like the look of them)
    ithaca Ny
    Ive run up to a 20mil on track with my old 8.5 square setup. My current winter project is 245 hoosiers on 17x9.5 arc8. 15 mil spacer looks like it should work once I switch to mcs with 2.25 spring i.d. Im around -4 degrees camber, clearance to my pfc bbk caliper is around 1 millimeter lol.
    Im sure you'll be able to make your work, you might just have to play around with spacers, camber, and fender rolling.
  1. Confirm fitment M54 Apex Arc-8: 17 x 9 ET30, 17 x 9.5 ET35?
    By Henway in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-04-2018, 08:14 PM
  2. Replies: 10
    Last Post: 05-07-2016, 12:19 PM
  3. Apex arc-8 front fitment issues, need help!
    By TylerG21 in forum 1991 - 1999 (E36)
    Last Post: 10-18-2013, 10:05 AM
  4. 4x100 17x8" APEX ARC-8 wheel E30 fitment
    By paintpro21 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 10-19-2010, 03:55 PM
  5. Checking Fitment: 17x9 Apex ARC-8's with 255/40/17 all around?
    By Rakshas in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-29-2009, 04:31 PM
