Results 1 to 10 of 10
Thread: iDrive shot, No heat...
    Nov 2019
    Atlanta, GA, USA
    2006 525Xi, 1990 325iC
    Greetings All,
    2006 525xi
    -iDrive has recently died and has black screen.
    -After turning the temperature dial knobs to the highest possible setting (82 F), only cold air blows out of all possible vents.
    -The car previously had a code for thermostat, so I figured that was the culprit. So, I have changed the thermostat and still no heat.
    -No coolant leaks.
    -A/C worked perfect this season.
    -Vehicle does not overheat.
    -No codes
    Questions:
    (1) Does iDrive settings need to be changed from “cold" to "hot"? (If so, is there a way to do this with the idrive being shot?)
    (2) If iDrive isn’t the culprit, what are other possibilities to troubleshoot?
    Thanks!
    Jan 2016
    Ca
    2001 525it
    Well if the idrive screen is black then clearly ther is something wrong how old is the battery
    Mar 2008
    Coquitlam, BC, Canada
    2003 530i
    No codes? Scanner used capable of reading BMW codes?
    Sent from my LG-H915 using Tapatalk
    Nov 2019
    Atlanta, GA, USA
    Quote Originally Posted by jclausen View Post
    The Idrive crashed a few weeks ago.
    Typical CCC failure. (Sending off for replacement tomorrow). To my understanding, there are settings in Idrive that could be causing this. However, I thought that the Idrive settings controlled center vents only.
    My 06 525xi has 0 heat, but A/C works just fine.
    Battery has been tested. It’s fine.
    Nov 2019
    Atlanta, GA, USA
    Update:
    Repaired CCC for less than $200. Everything is golden now!
    Feb 2018
    California
    05’ 525 6spd
    Quote Originally Posted by Bimmena View Post
    Update:
    I need to repair my ccc as well. Whom did u sent the unit to?
    Nov 2019
    Atlanta, GA, USA
    Quote Originally Posted by O5BMW525 View Post
    I am attaching 2 different links below.
    The 1st link is the guy that I went with. Obviously, he is overseas and I am in USA, but the entire process was completed in less than 7 days. (The price that you're willing to pay at your post office will determine overall speed. Once he received my unit, he had completed the repair in under 24 hours. Then the unit was on its way back to me to install. No additional coding was needed. Plug and play.) BTW, the unit has been installed for approximately 4 months now. All is still well. No complaints.
    https://rover.ebay.com/rover/0/0/0?m...2F324010251346
    The second link is to a guy who is in Florida. His prices are more expensive though. I chatted with the guy and he seems to know his stuff. But with the given price difference, I took my chances with the first link.https://www.ebay.com/itm/ANY-BMW-MIN...-/252977429658
    I hope this information helps.
    Disclaimer: I am not affiliated with any of the two above.
    Jan 2017
    Asheville, NC
    E30, e38 ,e46, e60,e90
    I swear I recall reading somewhere recently where someone was able to repair themselves with little trouble.
    Something about particular capacitors that go bad on the board?
    Anyone heard of this?
    I am going to have to address this soon, too, but have other issues to address, first.
    Dec 2020
    Houston texas
    2008 535i
    Heater work?
    Did your heater work after you had the CCC fixed?
    Nov 2019
    Atlanta, GA, USA
    Everything worked after the CCC was fixed. (There is a setting in “Climate” (I think that’s what it’s called) in which you have to make ensure that it is geared towards the red (indicating heat) vs blue (indicating cool).
    From my research, I’ve found that it’s usually 1 or 2 culprits that can affect the heater, (given that your car isn’t exhibiting any other crazy symptoms). CCC or heater control valve. See attached link.
    FYI, I had to replace mine apprx. 2 years ago or so because I wasn’t getting any heat, but it was a completely separate issue from when I didn’t have heat because of the CCC.
    Good luck.
    https://www.pelicanparts.com/techart...eplacement.htm
  1. High temp / over heat warning on iDrive screen!
    By Tony Rome in forum 2004-2010 (E60,E61)
    Last Post: 07-19-2013, 08:48 PM
  2. Real Carbon Fiber electric and heated mirrors for $330+shipping
    By Derek //M in forum BMW Parts For Sale
    Last Post: 09-02-2005, 04:41 PM
  3. Real carbin Fiber mirrors, heated and electric for $330
    Last Post: 03-06-2001, 09:17 PM
  4. Does heated seats = heated mirrors?
    By M3 Pete in forum 1992 - 1999 M3 (E36)
    Last Post: 03-03-2001, 08:32 PM
  5. How much do Vader Heated nonpower seats weigh?
    By M3D in forum 1992 - 1999 M3 (E36)
    Last Post: 03-02-2001, 02:02 PM
