Results 1 to 8 of 8
Thread: E83 Rear End Noise???
    Feb 2015
    Charlotte, NC
    2002 540i M-sport
    I'm helping sort out my niece's 2005 2.5L w/ 139k miles before she takes it back to NY for the winter. Originally it had a noise coming from the back underside that sounded like the Mind Flayer with indigestion. Replaced the rear drive shaft (Dorman) and guibo (MeyleHD). New tires (General G Max AS-05) went on and I took it out on the highway for a test drive. Side note I was amazed how high the 2.5 RPM's were at 80 MPH, nearly 3k! All of the original noise seems to be gone, now I'm hearing something new in the rear when I'm off the throttle. It seems to be a bit of a whining sound. Don't know if this is a wheel bearing, rear diff bushing or something else. In town, side to side turning does not seem to cause any noise, this is all straight line. Any thoughts? TIA
    Jan 2016
    Ca
    2001 525it
    If it's a wheel bearing the sound will change when the car is turning, loading the bearing then turning the other way will unload it decreasing the sound or diff
    Mar 2019
    ATLANTA GA
    456 X3s
    When was the rear diff fluid changed...if never or I don't know...it's time at 130k on the clock.
    Sent from my SM-G531H using Tapatalk
    Feb 2015
    Charlotte, NC
    2002 540i M-sport
    Quote Originally Posted by X3456 View Post
    Changing front and rear diff fluid is next on my punch list, xfer case and transmission have already been done. Fluid from both did not look that bad which makes me think both had been serviced at least once before.
    Cave Creek, AZ
    1993 850ci 2001 M5
    Check the rear differential mounting bushings for play
    Regards,
    Brian
    Cave Creek, AZ
    Feb 2015
    Charlotte, NC
    2002 540i M-sport
    I presume you mean #10 shown in this image. There are many others including #2 & #3. Do they all need to be replaced at the same time or is #10 the usual point of failure?
    https://www.realoem.com/bmw/enUS/sho...diagId=33_1199
    Cave Creek, AZ
    1993 850ci 2001 M5
    Bdevil, you are correct, #10 is usually the culprit. See my experience with that here:
    https://www.bimmerforums.com/forum/s...-bad-on-my-e83
    Regards,
    Brian
    Cave Creek, AZ
    Feb 2015
    Charlotte, NC
    2002 540i M-sport
    Thanks Brian, great write up.
  1. Idle and rear end noise problems
    By musclebound350 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-20-2004, 01:57 AM
  2. Rear end noise
    Last Post: 11-19-2004, 08:36 AM
  3. Rear end noise on E36! Need help
    By musclebound350 in forum Forced Induction
    Last Post: 11-16-2004, 03:17 AM
  4. rear end noises on a 330ci?
    By NC_CarbonM in forum 1999 - 2006 (E46)
    Last Post: 01-09-2004, 01:03 AM
  5. Rear end noise Q?
    By CWash36 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-14-2003, 03:12 PM
