Continuation from this prior thread: https://www.bimmerforums.com/forum/s...illion-miles-)
Hi gents, planning some refresh work on the engine (M52tu 2.8) and thinking I'd do the M54 intake manifold swap and headers (Raceland) while I'm at it.
Below is a full parts list* in detail. Buying stock parts for the most part but thinking I could do better with after market parts on some items. Any feedback or recommended products would be a big help on the following items.
-Spark plugs (stock are about double the cost of NKG or Bosch aftermarket?)
-Coolant hoses (is there a set that I might buy thats an upgrade from stock?)
-Water pump / water pump housing
-Tensioner and pulleys
*Full parts list:
cooling system:
1 - overflow hose (to expansion tank) - 11531436122
1 - hose clamp (for overflow hose) - 32411712735
1 - lower water hose - 11531716642
1 - upper water hose - 11531716641
2 - water hose clamps - 07129952119
1 - heater inlet pipe - 11531705210
1 - hex nut with plate - 07129904553
1 - outlet hose to expansion tank - 11531716643
1 - hose clamp to expansion tank - 07129952113
1 - cable tie - 32411112282
1 - Thermostat housing with thermostat - 11537509227
1 - water pump - 11517509985
4 - hex nut with plate - 07129904553
Valve cover:
1 - valve cover gasket - 11129070990
2 - valve cover mount cushion - 11121730356
2 - hex nut with plate - 07129904553
1 - valve cover oil seal - 11127526447
7 - stud bolt - 07129908102
12 - cap nuts with rubber washer - 11121738607
2 - hex bolt to ground - 07119913426
2 - hex nut to ground - 07119915502
PCV:
1 - vent pipe - 11611432559
1 - return pipe - 11157520035
1 - connecting line - 11611440317
1 - vent pipe clamp - 07129952104
1 - pcv valve - 11617501566
2 - pcv screws - 11617533331
1 - vent hose to dipstick - 11157532649
Misc
1 - serpentine belt - 11287636379
1 - oil filter housing gasket - 11421719855
2 - pressure hose seal - 32411093596
1 - pressure hose bolt - 32416852469
Intake manifold
1 - manifold gasket - 11611436631
1 - o-ring intake temp sensor - 13621743299
6 - o-rings for dist piece - 11617502761
1 - icv mounting garment - 11611432564
4 - screws for dist piece - 11617533331
9 - hex nut with plate - 07129905541
1 - fuel pipe bracket - 11617502272
1 - holder sucking jet pump - 11617502267
1 - hex nut - 07129904865
Vacuum
1 - sucking jet pump - 11611439396
1 - clamp - 64531356622
1 - hex bolt with washer - 07119915123
Exhaust
2 - exhaust manifold gaskets - 11621732969
2 - downpipes header gaskets - 18301440183
2 - screw plugs with gasket ring lam - 11621437517
1 - exhaust manifold (headers) - https://raceland.com/bmw-coilovers/z3-1996-2000/bmw-e36-z3-exhaust-header.html
16 - exhaust manifold suds - 11121744057
16 - exhaust manifold nuts - 11721437202
2 - Downstream O2 sensors - https://www.fcpeuro.com/products/bmw-oxygen-sensor-rear-bosch-15109#desc
Fuel preperation system
1 - throttle body gasket - 11611716174
6 - injector o-rings - 13641437486
1 - air intake o-ring - 13711720540
1 - air filter - 13721730449
WHY are you replacing all the hardware__is it all corroded?
It is wise to replace any locknuts and exhaust hdwr, but for the most part, the rest of it cleans up pretty good
You could do main and rod bearings, Piston rings, a valve regrind and timing chains, depending on mileage...
Three letters for you, sir. OCD.
Not replacing all the fasteners, just the ones that are visible mostly. They are rusty. Think the car spent a bit of time up north :/
Planning to buy a separate m52tu engine for a whole rebuild down the road some perhaps...that way I can take my time.
Needing some guidance on these items for now.
Should I stay all stock on these?
bimmerbum has these NGK plugs at half the price of stock plugs: https://shop.bimmerbum.com/products/3-00253-oem-ngk-high-power-spark-plug-set-for-m52m52tum54-12-12-9-071-003
Good move?
$195 - EMP Stewart High Performance Water Pump: https://shop.bimmerbum.com/products/3-00404-emp-stewart-high-performance-water-pump
Twice the price of stock water pump. Worth it?
M54/M52tu Aluminum Water Pump Pulley: https://shop.bimmerbum.com/products/3-00630-m54m52tu-aluminum-water-pump-pulley-11511436590
I feel like these are basic questions but its my first go at this…
Last, is it recommended that I proactively replace the electric fan (deleting the mechanical fan)? I’m pretty sure its the original fan
X2 on the Stewart water pump. One major part I didn't see on the list; Radiator! The plastic parts give up when your not expecting it, and can easily cost a head gasket, if your lucky.
-Donny
I did forget the vanos rebuild, though. Are these the best I can do?
http://beisansystems.com/index.html
spark plugs even cheaper.
https://www.amazon.com/Spark-Plugs-P...omotive&sr=1-5
I just overhauled my cooling system and here's my list (90% of the items came from a list posted by Randy Forbes in a similar thread). I even have the prices and p/ns. This is for an S52 roadster, but our engines should be pretty similar.
Check out my M Roadster projects and DIYs:
Cooling system part 1: https://youtu.be/ERqztIL1DPw
Cooling system part 2: https://youtu.be/-DnclDkn2hI
Power convertible top: https://youtu.be/KLYNqkCBh_M
Head unit removal: https://youtu.be/LKe9fPKrAqE
Also forgot to mention that now would be a great time to check your power steering reservoir. It will be easily accessible. The reservoir, hoses and fluid are really cheap. My reservoir and one of the hoses were coated in fluid that wasn't dripping to the ground. The actual fluid was black in color. Even if you don't have leaks, I would highly recommend flushing the fluid.
If you are planning to go in that deep to replace the fuel injector o-rings, might as well consider cleaning/replacing the injector filters and testing/refreshing the injectors. Just my .02.
2000 Z3 M Titanium Silver / Imola Red+Black Nappa
2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
Since 1987 12 euros / 2 kdms / 2 jdms
- Zach
Yes sir, I’ll have a closer look at these and do some comparisons. Many of the parts are the same as the m52tu. Many are not.
Sometimes I get a feeling that I will purchase the wrong aftermarket part and I’ll end up redoing the work...not saving time or money
That was the motivation behind this post.
Don’t know when to go stock vs aftermarket on many of these parts.
- Zach
Send your fuel injectors to http://www.doctorinjector.net/
Tony
"You can't sign away negligence."
Update: valve cover gasket, spark plugs and Vanos rebuild complete. Photos to follow.
Vcg was hard and obviously leaking. Had oil on top of all the plugs
Gents getting the attached now after the vanos refresh
Anyone seen this one before?
Does it mean it is not functioning at all? I’m thinking it functions with oil pressure. Correct?
After a cold start, at idle
