Results 1 to 5 of 5
Thread: Samsonas 6 speed dog box transmission/Tilton triple carbon. Ultimate BMW manual setup
    Nov 2005
    Linden, NJ
    F80, E36, X3"M"
    For sale: complete transmission, clutch, shifter, crossmember and driveshaft from my 1200whp E46 M3. Transmission is 6 speed H pattern with straight cut gears. Gearbox is serviceable and rebuildable. Based on ZF case, but longer due to the billet housing in the middle. Has E46 M3 larger input shaft. Sounds amazing, and is completely streetable if you want to sound like a race car driver when you get your Dunkin Donuts. Roughly 15k miles on trans, mostly street use. Clutch is triple disc carbon/carbon Tilton with hydraulic release bearing and VAC Motorsports flywheel. Clutch will hold 1200 ft/lbs tq. Comes with paperwork and thicker shim for if/when it wears. Has been serviced multiple times and has next to no wear after years of use. Shifter is Autosolutions. Has two different knobs, one with micro switch. Crossmember and 2 piece driveshaft are custom. $9000 for the entire package. $4000 for the clutch/Flywheel/hydraulics. $6000 for the trans, crossmember, shifter, driveshaft. sales@maximumpsi.com -Mike
    97 M3 - 8.94@164 - 8 sec street machine, all BMW driveline, factory ECU
    02 M3 - 9.74@145 - Maximum PSI stage 2 turbo kit, stock motor, factory ECU
    16 M3 - 9.3@151 - Built motor/twins
    15 M3 - 9.2@162 - Built motor/single turbo/Ecutek
    BMW SOB's turbo E30 - 8.72@158.39
    follow our latest builds and upcoming events! - facebook.com/maximumpsi - instagram.com/maximumpsi
    NY
    skateboard
    If only my money tree was in season
    ― George Orwell
    Nov 2005
    Linden, NJ
    F80, E36, X3"M"
    Sold
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Thank OBAMA.
    NY
    skateboard
    Quote Originally Posted by milKt View Post
    Thank OBAMA.
    ― George Orwell
  1. race transmission, dog box
    By CDCJON551 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-29-2013, 09:23 PM
  2. 1981 E12 535i 5 SPEED 225 DOG LEG TRANSMISSION
    By 81m535i in forum Drivetrain & Transmission Parts
    Last Post: 08-17-2011, 11:29 AM
  3. Dog Box Transmission
    By davidtm5 in forum Forced Induction
    Last Post: 02-02-2010, 07:37 PM
  4. Replies: 1
    Last Post: 02-18-2005, 02:08 PM
  5. E39 wiper gear box/transmission
    By flake540 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-10-2004, 11:39 AM
