Results 1 to 11 of 11
Thread: What DSSR with RTD shifter?
    Mar 2013
    St. Petersburg, FL
    '98 e36 sedan
    I’ve recently acquired a RTD non lockout shifter. I’m looking for a DSSR that is known to work well with it. Car is a 328i with ZF 5 speed. Thanks!
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    I used the AKG one but I've read that DSSR isn't really even needed?
    You will need solid motor/trans mounts though or you risk money shifting.
    Aug 2012
    Central, MD
    1995 M3
    Any DSSR with OEM dimensions should work. I'd expect the OEM single sided shift arm would work fine too. I guess the ideal setup might be one of those adjustable length DSSR's, but DSSR's and adj length DSSR's are damn pricey. I think DSSR's are probably one of the least performance/$ things we buy, and yep, I have one (and an RTD shifter).
    oskaloosa,ia
    '01 3.0 ZCoupe
    Mar 2013
    St. Petersburg, FL
    '98 e36 sedan
    I’ve got all solid mounts on the car. I don’t have a stock selector rod on hand so I’ll have to source one but I just figured a DSSR would be best. I’ve been looking at AKG but It’s 140$. Revshift is coming out with some so I tried calling them about it and no answer.
    Thanks guys!
    Oct 2019
    Socal
    e30
    Quote Originally Posted by golgo13 View Post
    By solid mounts, do you mean aluminum or do you just mean non-stock mounts (i.e. stiff polyurethane is fine)?
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Quote Originally Posted by f100 View Post
    I'm on 75D polyurethane mounts and have never had an issue in 2.5 years.
    Knock on wood!
    Aug 2012
    Central, MD
    1995 M3
    It's simple. The harder the mounts, the less the shifter moves.
    Oct 2019
    Socal
    e30
    Knock on wood!
    I have 75D mounts as well. I figured that's what you meant (i.e. not literally solid but just very stiff) but just wanted to be sure.
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Quote Originally Posted by aeronaut View Post
    This.
    Nov 2019
    NY
    1995 m3
    I have the Ireland engineering version... little to no difference and a PITA to install. Save your money towards something else.
  1. RTD Shifter Group buy
    By Grimm5698 in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 08-08-2023, 10:47 PM
  2. DIY: RTD Shifter with Stock Rubber Boot
    By OCRentAPopo in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 09-04-2019, 02:25 PM
  3. CAE vs RTD shifter
    By Butters Stoch in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 08-05-2019, 11:47 AM
  4. E36 WTB CAE or RTD shifter
    By Butters Stoch in forum BMW Parts Wanted
    Last Post: 08-12-2016, 03:52 PM
  5. Replies: 2
    Last Post: 11-28-2011, 03:13 PM
