Results 1 to 2 of 2
Thread: INPA SYS-0002 ECU Object Not Found Error
    Oct 2019
    Denver, Colorado
    2008 Mini Cooper S
    Hello, I'm rebuilding my 2008 Mini Cooper S and want to use INPA for a few things. I've done the installation of 5.01 and it connects to the car, but when I try to access and view all the modules, it displays "SYS-0002: ECU OBJECT FILE NOT FOUND". After numerous searches I found the following, but am confused with next steps.
    3.6 SYS-0002: ECU OBJECT FILE NOT FOUND
    Reason 1: If the external table T_GRTB.prg doesn’t exist in the directory C:\EDIABAS\ECU\ the error message will be displayed when You execute the job IDENT_FUNKTIONAL of a functional SGBD.
    Solution 1: You have to download the external table using the ECCO Web Export and copy it in the directory C:\EDIABAS\ECU\.
    Reason 2: The SGBD, which You want to start doesn’t exist in the directory C:\EDIABAS\ECU or is an old one.
    Solution 2: You have to download the SGBD using the ECCO Web Client and copy it in the directory C:\EDIABAS\ECU\.
    Apparently I need an additional file/table, but this is where I'm lost. The file(s)"R56.PRG" & "SGBD_R56" (text file) are in the EDIABAS\ECU folder, but I'm unclear on my next step.
    Any help or guidance would be appreciated.
    Jun 2010
    United Kingdom
    None
    Still need help with this?
  1. INPA: SYS-0005: OBJECT FILE NOT FOUND error.
    By TheJayP in forum Diagnostic Software
    Last Post: 11-25-2018, 11:53 AM
  2. INPA Sys 0005 Object Not Found (E36)
    By straight six m3 in forum Diagnostic Software
    Last Post: 12-03-2014, 07:29 PM
  3. INPA 4.4.7 @ error sys-0002 ECU
    By Usernamehere in forum Diagnostic Software
    Last Post: 02-10-2013, 09:19 AM
  4. SYS-0005: OBJECT FILE NOT FOUND - NCS Expert
    By aleks001 in forum Diagnostic Software
    Last Post: 02-22-2012, 10:01 AM
  5. NCS Expert error: "SYS-0008: JOB NOT FOUND"
    By fishbert in forum Diagnostic Software
    Last Post: 01-16-2011, 05:31 PM
