Results 1 to 4 of 4
Thread: Snow Performance Methanol Injection Kits - Lowest Price + Free Shipping!
    Jan 2017
    Las Vegas
    Talking Snow Performance Methanol Injection Kits - Lowest Price + Free Shipping!
    http://www.ExtremePowerHouse.com
    Why shop with us?
    Lowest Price Guarantee: We do our best to always have the lowest price on our website, but if you found an even lower price somewhere else let us know. We will match the other price and thrown in an extra $25 store credit towards your next purchase.
    Financing: We offer 6 months no interest financing. Get the products now, pay later. You can at anytime pay the full amount or make partial payments during these 6 months. If after 6 months, you still have balance remaining on your account there will be a minimum monthly payment with interest applied, subject to credit approval.
    Customer Service: We offer the best customer service, period! Don’t take our word for it, check out what our customers have to say about Extreme Power House https://www.x-ph.com/customer-reviews/
    Hours: We are open 7 days a week from 8 AM to 11 PM Pacific Time.
    Contact us:
    For any questions you can pm / email Mike@x-ph.com or call 725-221-5267. If you contact us during business hours, expect a reply within the hour. If you contact us outside of the regular business hours, expect a reply within 6 hours.
    Chat: Looking for an immediate response to your questions? Go to our website www.x-ph.com and use our chat functionality.
    Payments: You can make a purchase directly on our website www.x-ph.com or give us a call at 725-221-5267 and we can process your order over the phone.
    Shipping: Expect to get a tracking number from us same day of your order completion. We try our best to get the products delivered to you ASAP. We ship items using USPS, UPS and FedEx. Contact Mike@x-ph.com for expedited shipping options.
    Inventory: We stock all the popular products at our Las Vegas warehouse. If item is not in stock, we will get it drop shipped to you directly from the manufacturer’s location.
    XPH Rewards:
    We now offer Extreme Power House loyalty points to all our loyal customers. Earn 1 point after every $1 you spend with us. Earn more by sharing our website on social media and referring your friends.
    Newsletter: Join our newsletter for the latest XPH news, exclusive deals, group buys and coupon codes. We also offer exclusive newsletter flash sales.
    Order Link
    https://x-ph.com/snow-performance-methanol-injection-kit/
    Stage 1 Boost Cooler Forced Induction Water-Methanol Injection Kit (Red High Temp Nylon Tubing, Quick-Connect Fittings)
    Description
    Race gas quality fuel on pump gas! Increase your pump gas octane by 25 points and make more power efficiently with a cooler running motor! The Snow Performance Stage 1 Boost Cooler water methanol injection kit is available for all forced induction applications (Supercharged/Turbocharged) and uses a adjustable boost switch to inject a fixed amount of water methanol into the system until boost goes below the switch set point. Proven to deliver 30-70 HP increases to all forced induction applications! This makes it a good choice for low to medium boost set ups, drag race applications, and vehicles with a positive displacement supercharger (Roots/Twinscrew) looking for an octane enhancement and cooler intake charge. Activation can also be set up through any other user chosen switch, such as a full throttle switch, nitrous switch, etc.
    This kit utilizes the only OEM approved water methanol injection pump on the market with proprietary heat flange, twin seals, and custom motor winding to run cooler and longer than the competition. The Extreme Environment 300 PSI UHO Pump is designed to be in the elements with O-Ring connections that are then sealed and potted to ensure no moisture can enter the pump internals. Compare this to pumps that us a pump "sleeve". These sleeves will keep moisture around the pump unit leading to corrosion as well as trap heat to greatly decrease pump life. The Stage 1 comes standard with 100% methanol resistant components using stainless steel, nickel plating, EPDM, and hard anodizing to ensure years of continued use. Tie that in with new Snow Performance ACU-SEAL compression fittings for guaranteed leak free operation even when using 100% methanol. For a extremely robust, reliable water methanol injection experience that won't break the bank look no further than the Snow Performance Stage 1 Boost Cooler !
    Features:
    U.S.A. Made
    Adjustable Water Methanol Engagement & Monitoring
    Recommended For High HP, Drag Race, and Positive Displacement Supercharger Applications
    Supports 1,000+ HP
    100% Methanol Resistant (Stainless Steel, Nickel Plating, Hard Anodizing, EPDM)
    Snow Performance Hyper-Sonic Water Methanol Nozzle
    Snow Performance ACU-SEAL Water Methanol Compression Fittings
    Snow Performance OEM Approved Extreme Environment 300 PSI UHO Water Methanol Pump
    Snow Performance Running "S" Engraved Low Profile Nozzle Holder
    Snow Performance Running "S" Engraved Low Profile High Flow Check Valve
    Stage 1 Boost Cooler Forced Induction Water-Methanol Injection Kit (Stainless Steel Braided Line, 4AN Fittings)
    Description
    This kit utilizes the only OEM approved water methanol injection pump on the market with proprietary heat flange, twin seals, and custom motor winding to run cooler and longer than the competition. The Extreme Environment 300 PSI UHO Pump is designed to be in the elements with O-Ring connections that are then sealed and potted to ensure no moisture can enter the pump internals. Compare this to pumps that us a pump "sleeve". These sleeves will keep moisture around the pump unit leading to corrosion as well as trap heat to greatly decrease pump life. The Stage 1 comes standard with 100% methanol resistant components using stainless steel, EPDM, and hard anodizing to ensure years of continued use. Tie that in with new Snow Performance ACU-SEAL compression fittings for guaranteed leak free operation even when using 100% methanol. For a extremely robust, reliable water methanol injection experience that won't break the bank look no further than the Snow Performance Stage 1 Boost Cooler !
    Features:
    U.S.A. Made
    Supports 1,000+ HP
    100% Methanol Resistant (Stainless Steel, Hard Anodizing, EPDM)
    Stage 2.5 Boost Cooler Forced Induction Progressive Water-Methanol Injection Kit (Red High Temp Nylon Tubing, Quick-Connect Fittings)
    Description
    Unlock 50-70 HP on your boosted vehicle while decreasing your air temps by up to 100 degrees! Increase your pump gas octane by 25 points and make more power efficiently with a cooler running motor! The Snow Performance Stage 2.5 Boost Cooler water methanol injection kit is available for all forced induction applications (Supercharged/Turbocharged). The Stage 2.5 uses the progressive VC-50 controller (52mm Gauge) that proportionally injects more or less water methanol according to boost pressure. Start and full points are adjustable for engagement and delivery curve to match what the engine requires. Proportionally injecting according to boost pressure gives a accurate delivery of water methanol and allows cooling and performance improvements over a wide range for improved drivability. Especially helpful for direct injected engines to remove 100% of carbon build up on the valves. Recommended for all street/strip driven forced induction vehicles using a turbo or centrifugal supercharger (Procharger/Vortech) looking for cooling over a wide range.
    The VC-50 (ISO 9001 Manufactured) controller offers the functionality of a boost gauge and water methanol controller all in one! Highlighting a bright 7 color (Blue, White, Red, Yellow, Orange, Purple, Green) O-LED screen displaying boost, percentage of injection, low level, secondary stage activation, prime button, and system fault codes directly on the screen. You can tailor the controller color to match your OEM gauges or mix and match up to two colors!
    This kit utilizes the only OEM approved water methanol injection pump on the market with proprietary heat flange, twin seals, and custom motor winding to run cooler and longer than the competition. The Extreme Environment 300 PSI UHO pump is designed to be in the elements with O-Ring connections that are then sealed and potted to ensure no moisture can enter the pump internals. Compare this to pumps that use a pump "sleeve". These sleeves will keep moisture around the pump unit leading to corrosion as well as trap heat greatly decrease pump life. The Stage 2.5 comes standard with 100% methanol resistant components using stainless steel, nickel plating, EPDM, and hard anodizing to ensure years of continued use. Tie that in with new Snow Performance ACU-SEAL compression fittings for guaranteed leak free operation even when using 100% methanol. Whether running a supercharger, turbo, or high compression motor the Stage 2.5 Boost Cooler will make the induction charge colder, denser, and increase 91 octane fuel to 116 octane race gas levels allowing full power all the time!
    Features:
    U.S.A. Made
    Adjustable Progressive Water Methanol Engagement & Monitoring
    Digital Boost Reading (1-50 PSI)
    Recommended For Street Driven Turbo and Centrifugal Supercharger Applications
    Supports 1,000+ HP
    Stage 2.5 Boost Cooler Forced Induction Progressive Water-Methanol Injection Kit (Stainless Steel Braided Line, 4AN Fittings)
    Description
    Features:
    U.S.A. Made
    Supports 1,000+ HP
    Stage 2.5 Boost Cooler N54/N55 Direct Port Water Methanol Injection Kit
    Description
    Snow Performance has combined performance, quality and easy installation in this new water-methanol injection system engineered specifically for N54/N55 BMWs. Increase your pump gas octane by 25 points and make more power efficiently with a cooler running motor! Complete with custom water-methanol injection throttle body spacer plate, braided stainless line, and 4AN fittings offering un-surpassed reliability and ease of install. The Stage 2 uses a progressive VC-50 controller(ISO 9001 Manufactured) that proportionally injects more or less according to boost pressure. Start and full points are adjustable for engagement and delivery curve to match what the engine requires. Proportionally injecting according to boost pressure gives an accurate delivery of water-methanol and allows cooling and performance improvements over a wide range for improved drivability. The VC-50 controller (52mm gauge) offers the functionality of a boost gauge and water-methanol controller all in one! Highlighting a 7 color(Blue, White, Red, Yellow, Orange, Purple, Green) OLED screen displaying boost,percentage of injection, low level, secondary nozzle activation, prime button,and 2 fault codes directly on the screen you can tailor the controller to match your OEM gauges or mix and match up to two colors.
    Snow Performance Direct Port Injection Plates are the easiest, best selling way to mount water-meth nozzles. Simply fit between the head and intake manifold and enjoy the placement of 6 Snow Performance Hyper-Sonic™ nozzles right where you need it! Our Direct Port Injection Plate is the easiest and best way to install water methanol on your BMW N54/N55 Engine.
    Includes:
    Direct Port Injection Plate for N54/N55
    OEM O-Ring gaskets to seal between injection plate and head
    Required Hardware for Installation
    Instructions for fitment on N54/N55 style engines
    Hardlines plumbed to distribution rail
    Six #2 Nozzles installed in plate
    High flow water methanol solenoids
    N54/N55 engine specific boost tap
    Everything needed for installation
    *Specify nozzle sizes in order comments otherwise the kit will come with No.2 nozzles*
    *Note- For safety, a solenoid (part #40060) must be used when injecting post throttle body to prevent vacuum siphoning
    Jan 2017
    Las Vegas
    Jan 2017
    Las Vegas
    Jan 2017
    Las Vegas
  1. Lowest Price + Free Shipping on VRSF Products - IN STOCK + SAME DAY SHIPPING!
    By mike@XPH in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 02-20-2020, 11:43 AM
  2. E36 E36 M3 Supercharger Parts - Snow Performance Methanol, 13psi Kit, Tunes, Brackets, ++
    By nate325 in forum Forced & Chemical Induction Parts
    Last Post: 05-08-2014, 08:17 AM
  3. :: ECS Tuning :: FK Coilover Kits **BLOWOUT Pricing** ~ FREE Shipping ~ (ROUND 2!!!)
    By ECSTuningJames in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 06-27-2010, 10:59 PM
  4. :: ECS Tuning :: FK Coilover Kits **BLOWOUT Pricing** ~ FREE Shipping ~ (ROUND 2!!!)
    By ECSTuningJames in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 03-08-2010, 09:06 AM
  5. :: ECS Tuning :: FK Coilover Kits **BLOWOUT Pricing** ~ FREE Shipping ~
    Last Post: 01-28-2010, 02:47 PM
