Results 1 to 18 of 18
Thread: clutch...another thread
    Aug 2012
    Central, MD
    1995 M3
    I know. Another clutch thread.
    Stock E36 S50 engine. Track only car. Transmission is getting replaced (current one won't stay in 4th). Need to do a quick job so I can finish the season, hopefully VIR in 2.5 weeks.
    I was going to just do a Sachs OEM clutch/PP/TOB replacement while in there. But folks seem happy with gripforce stuff.
    This seems too good to be true, $250 for a PP, single mass steel flywheel, and sprung clutch????
    How much break-in do these need?
    https://www.ebay.com/itm/FX-STAGE-2-...6/163527156939
    MINIz guy's Avatar
    MINIz guy is offline #buttstuff2k14 BMW CCA Member
    Bear, DE
    rolls coal
    Wow they've gotten cheap. I run that. Pretty sure I had 100 miles on mine before I autocrossed it. Still kickin' 30k miles later. It's a very grabby and heavy clutch.
    Aug 2012
    Central, MD
    1995 M3
    Hmmmm, thanks for the feedback. I don't like grabby.
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    I loved mine. I had the chromoly flywheel and 6 puck fxracing ebay setup. Installed it and then trailered straight to a DE. Abused the shit out of that clutch and loved every minute. Didnt slip it, just unloaded it and went like a bat outta hell.
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by olemiss540 View Post
    Any problems driving up on a trailer with your clutch setup?
    Nov 2005
    MA
    Cayman S, Golf GSW, E30
    My Gripforce is doing great. I can look up details later, but its the light aluminum flywheel with organic non-sprung disc. It actually feels and drives great. Very easy to modulate. I was amazed.
    I did OEM TOB, stainless steel ball pivot, new pivot arm, all that as well.
    Springfield, IL
    Quote Originally Posted by aeronaut View Post
    Naw. Just a bit grabber than stock but no where like some of these racing transmissions that have to be revved like crazy to budge forward.
    Aug 2012
    Central, MD
    1995 M3
    Thanks all, great feedback. I'm going with the FX steel light(er) weight flywheel, organic sprung clutch, and HD PP. Basically, a stage 1 setup.
    But, it sounds like the unsprung clutch plate is fine too?
    Jun 2005
    Concord, NH
    08 E90M3; 99 E36M3 Turbo
    I ran an unsprung disc AA heavy duty clutch on a 13 lb aluminum flywheel years ago and it was great. Normally you use sprung disc with a single mass flywheel, but unsprung can work fine. With a light flywheel, raising the idle speed in the tune makes engagement easier and reduces gearbox noise.
    Nov 2005
    MA
    This is the kit i'm running:
    https://gripforce.com/fx-racing-stag...3-e34-e36-e39/
    I'm really happy with it. I was expecting a #becauseracecar clutch, but it's actually easier to drive than the old stock. I've driven through cities and stop and go traffic no prob. I'd highly recommend it. The quick revs are nice as well for heel toe'ing and such. The gearbox does rattle a bit when its good and hot, but it doesn't bother me for my use case. Still at stock idle speed.
    Definitely use a quality throw out bearing if you use these kits, though.
    Aug 2012
    Central, MD
    1995 M3
    Thanks! I was going to go with the steel (still lighter than OEM) flywheel, but your experience sounds enticing.
    Springfield, IL
    I just have PTSD from all of the 15 year old UUC LWFW threads on how aluminum flywheels explode harmonics!!@!
    Aug 2012
    Central, MD
    1995 M3
    HA! Yea, doing my clutch research, I ran across quite a bit rambling on those.
    MINIz guy's Avatar
    Bear, DE
    rolls coal
    The stage 2 is grabby, but not 6-puck grabby. It's "why do I need this much clutch pressure for 190hp" grabby.
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    Yeah, I'm expecting the UUC Stage 2 lightweight flywheel I installed in 2005 to explode any day now!
    Neil
    Springfield, IL
    Quote Originally Posted by NeilM View Post
    Neil
    Those were the good old days before facebook and instapost stole all of our beloved bimmerforums traffic...
    Oct 2005
    Canberra, Australia
    1993 BMW 325i Coupe
    I ran a stage 2 gripforce clutch and flywheel in my 325 for about 8-10yrs of street, drag strip and track driving with no issues at all! It was a pretty stiff and grabby feel, but was easy to drive up on the trailer.
    I now have one of the stage 3/4 6-puck unsprung clutches, and it's a prick to get on the trailer. So grabby and no give whatsoever, but pretty awesome out on the track and so far hasn't slipped with my new turbo build but I won't be tracking it for another couple of weeks, so will see how it holds up then.
    E36 1993 325i Coupe - Gt3582 turbo build COMPLETE!
    DomsE36Garage Youtube Channel
    Aug 2012
    Central, MD
    1995 M3
    I posted an update in my "build" thread, but for the record...
    Gripforce sent 8.8 grade bolts for the flywheel, which require 105Nm torque per Bentley. 105Nm and M12 grade 8.8 bolts aren't meant for each other.
    Ordered 10.9 bolts from McMaster.
    Also, packaging of the kit was shoddy. PP and flywheel had some dings, all cosmetic but could have been bad. To gripforce's credit, they responded quickly and offered a few bucks refund.
  1. Another clutch bleed thread
    By weedshoes in forum 1992 - 1999 M3 (E36)
    Last Post: 07-09-2018, 10:42 PM
  2. Another Clutch Disengagement Thread -- Bent Clutch Pedal?
    By vladimrhtg in forum 1991 - 1999 (E36)
    Last Post: 05-29-2017, 12:59 PM
  3. Clutch Bleed - yes I know yet another thread about it
    By heathy in forum 1983 - 1991 (E30)
    Last Post: 05-31-2010, 05:10 PM
  4. another squeaky clutch pedal thread... fixed, but still flimsy
    By pwhitt in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-07-2009, 05:49 PM
  5. Removing Fan Clutch (another thread, sorry!)
    By JonUK in forum 1991 - 1999 (E36)
    Last Post: 03-31-2002, 04:38 AM
