Results 1 to 24 of 24
Thread: Ebrake cable clip
    Sep 2018
    Houston, TX, USA
    1999 BMW Z3 Coupe 2.8
    Ebrake cable clip
    Anyone know how to get this guy to stay in the clip?
    Ebrake cable keeps popping out of clip on the bottom of fuel tank. :/
    Ignore the blue tape...failed attempt at a temporary solution.
    Lexington, KY
    99 Coupe Hell Yeah Red
    How about drilling a small hole at the base and using a zip-tie?
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    The cable clip on the tank sounds like it has lost its grip, maybe appears to have one side broken, compared an intact one in this photo.
    The tank clip part does not seem to be listed, but maybe you could remove the broken clip and attach a frame clip to the tank with epoxy:
    https://www.ecstuning.com/b-genuine-...h/35511161876/
    BMW MOA 696, BMW CCA 1405
    May 2013
    USA
    2001 Z3 3.0/5 roadster
    After forcing mine into that clip I realized that the internal cable was binding so I pronounced it a bad idea. Of course the sheathing may have gotten squashed a little in the process.
    Aug 2016
    Spring TX, USA
    2000 BMW Z3 2.3
    I drilled a small hole in the clip above the cable, and used stainless steel safety wire (With the appropriate speed safety wire pliers) to secure those cables for the last 3 years now. When they pop out of the clip, it releases tension on the e brake system and makes your car rattle like the rear wheels are coffee cans full of popcorn kernels.
    Sep 2018
    Houston, TX, USA
    Quote Originally Posted by Zoupe6 View Post
    Thought about that but not sure there’s space to get a drill up to the area.
    Might need a new tool
    Sep 2018
    Houston, TX, USA
    Quote Originally Posted by Vintage42 View Post
    Thought about it. If I can’t get a tie around it, I might.
    Something about using epoxy makes me feel like I’m doing it wrong...personal problem
    Sep 2018
    Houston, TX, USA
    Quote Originally Posted by TommyMaddox View Post
    How did you get a drill up there? I’ll have to google “safety wire”. Sounds stronger than a zip tie tho
    Sep 2018
    Houston, TX, USA
    Quote Originally Posted by Dakar Ole View Post
    Interesting yours are too tight? Maybe some silicone spray. They should pop in
    Aug 2016
    Spring TX, USA
    2000 BMW Z3 2.3
    Quote Originally Posted by solimans View Post
    https://drive.google.com/file/d/19pJ...ew?usp=sharing
    You can kinda see in the bottom of this shot. Two small holes drilled per bracket with what I recall was a small right angle air drill, and stainless steel safety wire used with this type of safety wire tool
    https://www.amazon.com/Milbar-Safety.../dp/B0049C9EQ6
    You can of course use something cheaper. I'm pretty sure my friend got his in the late 60's early 70's.
    Sep 2018
    Houston, TX, USA
    Many thanks
    Lexington, KY
    A flexible arbor might work if you don't have a right angle die grinder.
    Oct 2012
    Louisville, KY
    ... Something about using epoxy makes me feel like I’m doing it wrong...personal problem ...
    So if you do stick another clip on the plastic gas tank, use whatever BMW used to stick their clip ;-)
    May 2013
    USA
    You'd think it would just pop in but the force needed was rather tremendous and given the location and on my back my fingers were in no way gonna cut it, even with silicone grease. I managed to tap it in with a 1/2" brass rod. Then I removed it after the brake cable was not fully releasing. My guess is it's been out since shortly after assembly.
    Aug 2016
    Spring TX, USA
    2000 BMW Z3 2.3
    FWIW I would have mine be fine prior to this modification for a few days or weeks, but eventually there would come a time where there was enough rear trailing arm travel to drop and pull the cable out of the holder, and then it was back to rattling. So keep an eye on it if you aren't positively securing it.
    Aug 2019
    Central NJ
    1998 Z3M Roadster
    Home Depot sells different size cable clips that would probably hold the E brake cable. The 3/8" size should work if you can find a proper size fastener to hold it to the pan.
    Sep 2018
    Houston, TX, USA
    Gonna give it a try, many thanks. Picked one up on amazon
    Sep 2018
    Houston, TX, USA
    You make a good point here sir
    Sep 2018
    Houston, TX, USA
    Quote Originally Posted by spankNZ View Post
    They just might. Good thinking. If I fail with the tie...Home Depot and epoxy
    Sep 2018
    Houston, TX, USA
    Update on this one...finally got some photos:
    Sep 2018
    Houston, TX, USA
    Sep 2018
    Houston, TX, USA
    Ended up using these clips from the Home Depot and some epoxy. Vintage42’s idea, thank you for that sir
    Sep 2018
    Houston, TX, USA
    Ebrake cable clip
    Thank you, spanknz as well
    Sep 2018
    Houston, TX, USA
    On the left side I put a clip in front and in back of the stock clip. The left stock clip was not holding for me
  1. noise coming from ebrake cable???
    By bimmerboy82 in forum 1991 - 1999 (E36)
    Last Post: 10-21-2006, 08:05 PM
  2. FS: E36 Ebrake cable - NEW 40 shipped!
    By mypreludeisred in forum BMW Parts For Sale
    Last Post: 07-11-2006, 09:50 PM
  3. FS: e36 ebrake cable, brand new
    Last Post: 04-26-2006, 12:15 PM
  4. Anyone have a 320i/318i ebrake cable they can measure?
    By 02tom in forum 1983 - 1991 (E30)
    Last Post: 05-21-2005, 05:00 PM
  5. Anyone have a 320i/318i ebrake cable they can measure?
    By 02tom in forum 1975 - 1983 (E21)
    Last Post: 05-21-2005, 04:59 PM
