Results 1 to 10 of 10
Thread: X3 diagnosis for Transfer Case or VTG controller
    Oct 2019
    Huntington Beach Ca
    2004 x3 3.0
    I am trying to figure out why i cannot get my transfer case to engage in my 2004 X3, Initially i got the usual 3 light display on the dash, and assuming i had a stripped gear in the actuator, i ordered and when it arrived i replaced it, no no avail.
    I get the 5F39 code on my somewhat limited scan tool. I removed the actuator again and made sure the motor worked (it does) and then continued to test the things i thought relevant, i must admit im a reasonable newbie to the beamer, but a master tech that ran an indy repair shop for 20 years. I removed the motor again, and grounded it out just in case it was needed, then started the car and tried to see if the gear rotated. It didnt. I then checked the input voltage to the controller in the back of the car (the internet is a wonderful thing for finding components!) 13.65 volts. The output however to the transfer case was only 4 volts (8 with no load). I even went as far as to run the car with all four wheels in the air and again see if the controller tried to engage the front wheels, by running the actuator (that i had removed and was hanging, and marked so i could see if it rotated). Then i rotated the stub for the transfer case actuator by hand, and voila, i had the front axle engaged.
    Whew! long day of diagnosis but i find im no closer than i was a day ago. Just for reference, the wheel speed sensors read fine, and my limited scan tool says the actuator motor is receiving 13.65 volts (which it is not). Is it possible the transfer case control module is faulty? The classification resistor? Any enlightening as to the operation of all these systems or your experienced opinion would be greatly appreciated.
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved to the model specific discussion area.
    88M3 AW 43k miles Project FS
    Kamloops, BC Canada
    1998 Z3
    Not sure if this will help at all, but if you had the "control unit, transfer box" the electronic control which is under the rear compartment floor, disconnected at all, it has to be properly reconnected, i.e. reconnected when the battery is disconnected and there is no power. Once electronic control reconnected, battery connected again. Not sure if this applies.
    Oct 2019
    Huntington Beach Ca
    2004 x3 3.0
    hmmmmmm
    Quote Originally Posted by dmytro View Post
    Thanks! Im not absoluely sure, but i beleive my first tests were done before i removed the module and yook off the cover to inspect for a bad trace, bulging cap ........ but you can bet im going out to the shop to repeat!
    Kamloops, BC Canada
    1998 Z3
    Please note also that disconnecting the battery will cause 3 lights on dashboard to go on, (airbag, brake, and another one) and they will only extinguish after a short drive, less than 100 meters, but I don't believe that running the car with all four wheels in the air is the same. Good luck.
    Jan 2016
    Ca
    2001 525it
    The most common issue with those is the plastic gear breaking
    Oct 2019
    Huntington Beach Ca
    2004 x3 3.0
    Hi all thanks for the advice, turned out to be the VTG controller after all, now i just need to reset the adaptives.........
    Mar 2019
    ATLANTA GA
    456 X3s
    Is this the
    Step #1 turn key (but not engine) to on
    Step#2 use foot to hold accelerator completely to the floor while doing the above for 25 seconds
    Step#3 now turn car on straightway and drive
    I've seen positive results over a couple days time if done correctly
    Sent from my SM-G531H using Tapatalk
    Mar 2019
    ATLANTA GA
    456 X3s
    I've experience this same thing what has been your results this far? And how many miles do I have on the car???
    Jul 2021
    South Africa
    2004 BMW X3 3.0i
    E 83 VTG - more problems
    Perhaps someone out there can help me. E83 X3 2004. Got the deadly 3 lights, removed VTG, replaced the plastic gear, test ran the VTG motor which works but when I refitted it, I start the car to a stronger than clicking sound from the area.5 distinct clicks and then it stops. Leads me to believe that the VTG isn't coupling witht the TC. Getting faults 5463, 5464, 5208 and 52D1.
    Any suggestions would be appreciated.
  1. X3- transfer case
    By hdrevenga in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 04-17-2020, 06:06 PM
  2. BMW X3 2004. Diagnostic computer error message "5dea Transfer case Temperature
    By Northcliff in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 12-09-2017, 01:13 PM
  3. BMW VTG Transfer Case Control Unit 27607607980 - No Longer Available
    By BMWcrocodile335 in forum Drivetrain & Transmission Parts
    Last Post: 10-20-2015, 01:34 AM
  4. :: ECS Tuning :: xDrive ~ X5/X3 ~ OEM BMW Transfer Case Fluid ~ Now Available!!!
    By ECSTuningJames in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 04-08-2011, 09:49 PM
  5. DIY - Changing X3 transfer case fluids
    By Borderline in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 05-28-2008, 01:18 AM
