Just happened yesterday when the wife was driving the car. I did a full timing kit from ecs about 40k miles ago, no tensioner fail, pretty much a mystery at this point for the failure. I've considered all options and just finding another motor and swap over the endless amount of new OEM parts purchased over the last two years seems to be the most logical solution.
Dude that sucks.
Such a clean engine.
I wonder what caused this.
Wow, a broken chain is really rare.
So you now have some bent valves.
I could type out a novel as to how nice the engine was, everything from injectors to the vanos was bought new OEM. I replaced fluids every 2 months regardless of miles, replaced plugs every 6 months regardless of miles and I have around 10k in receipts for parts alone purchased in the last 3-4 years, hell, I was even replacing parts just because they were weathered. Its sad, very sad but the good news is I can swap all thoes parts over to the transplant motor.
Jim, valves are definitely bent.
The whole stud unscrewed when I pulled the VC and I removed the nut before reinstalling it.
Good news, scored a long block. 100k on it, guy bought it from a German specialist yard for 2k as a swap for his 3 series. He decided to go another route and sold it to me for $200.
The Phoenix will rise again.
I've only ever seen the chain fail like that once before, and that was on an L322 Range Rover where the owner kept driving it after the guides went bad. In that case it was no mystery, but in your case it's truly a freak occurrence. Presumably some manufacturing defect in the chain that took a very long time to surface.
1995 525i 5-speed - Thread
A mystery is right. I'm on the same page as you, I'm thinking it was just a manufacturing time bomb. My good buddy who owns Migliore Motorwerks has a theory that the tensioner lost oil pressure somehow, chain slacked then busted on the vanos tooth (which makes a bit of sense as the teeth are sharp as a chisel).
Right now I'm making a parts list for the donor motor, this is what I have atm.
- front and rear main seals
- upper and lower pan gaskets
- tensioner overhaul (chain, guide's, tensioner, oil separator and associated gaskets
- water pump, valley pan and crossover gaskets, O-rings for transfer pipe's
- intake gaskets
- exhaust gaskets
- valve cover gaskets
- alternator gasket
- a/c O-rings
- new spark plugs
- new oil filter, liquid molly MoS2 10-40
Anyone chime in if you have any suggestions.
Figured since I have other things planned for the 540 (ohlins coilovers, M5 lsd, motec standalone and more) that I might as well turn this into my build page.
What you need to know:
- 2000 540i/6 in Titanium Silver
- Full 03' facelift conversion (bumpers, headlights (01' serviceable ones), taillights, black headliner and plastics, sunshade's
- Dynavin N6, replaced all speakers with infinity, home brew parcel shelf sub box holding 2 infinity 1100w 10" subs (the box is built so one sub is fully enclosed and the other ported with a custom designed and 3d printed port tube), 2 alpine amps (one running the subs and the other running mid and highs)
- 19" M wheels. 19x8.5 front (235/35), 19x9.5 rear (265/30). 0.5" spacers.
- JB racing flywheel w/ M5 pressure plate and disc
-CDV delete
- Cat back exhaust with magnaflow single chamber, gutted cat's
- Mallory fuel pump
- m60 intake manifold
- Bosch coils
- 4 hole Bosch injectors
- Modified OEM airbox w/ oil-less k&n filter
- DUDMD tune
- Full front suspension overhauled
There is more stuff but I'll go over it down the line, I will also go over more of the new engine components when I document the swap.
Please confirm, but that new engine looks like a m62, not a tu.
Sorry for your difficulties, as that's not a normal failure.
M62'S cannot become m62 tu's as piston clearance is an issue with no valve notches.
Just out of curiosity how did you come to the conclusion that it's not a TU? With the photo I provided, it doesn't show much BUT you can tell it's a TU by the valve cover, it has the larger hump to accommodate the vanos (TU). Anyways, here is a photo for ya, vanos solenoid and FBW throttle body.
So it is.
I said, please confirm.
That side picture left some details to the imagination.
there's like 5 dead spot on giveaways it's a TU engine. Among other more obscure details, you can spot quick connect hoses, single fuel line and the VANOS unit on the intakes.
OP. I'm terribvly sorry, I know what it is like spend big bucks in obsessive maintenance just to have pampered stuff failing on you while others stretch service intervals and cut corners and their stuff lasts 2x.
Diehard E39 driver.
I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
"Your momma's so ugly she makes Bangle cars look nice"
My apologies to all that think I'm an idiot know nothing.
I was working off this picture, and even blown up, the vanos valve cover bulge is not defined, can't see any quick disconnect hoses, and a tu one piece fuel line for e39 is on the other side, so impossible to see.
I did say please confirm.
Not enough room for past/present garage
Thank you sir. Yeah that's the part that eats me up inside, nothing but the best parts and vigilant when it comes to preventative maintenance. It's just a kick in the nuts.
Some more bad news, broke down the transplant motor and it appears the guy I got it from did not properly store the engine. There is water corrosion in 3 of the intake ports and it's bad enough that I will need to have the heads cleaned, new valve guides and seats at the minimum. There is also one cylinder that is questionable as I can feel pits (from the water corrosion) and there is definite wear on the alusil coating.
So with all that said I'm at a standstill atm. Not sure if I look for another engine or do I spend the cash to have machine work done (use the heads from the donor and the original short block). From my calculations a refresh could be as much as 3.5k+ , $800 for heads, $1000 for block work (cleaning, surfacing, rings, rod and crank bearings), $1500 for full timing kit (OEM parts) and then another $200 for miscellaneous gasket seals.
I know some people are going to say, "why bother with the bottom end?". Well there is so much fine metal shavings that I would not be comfortable running it without a full breakdown and cleaning and if I'm doing a full breakdown then I would be a moron not to refresh it as well.
Rock and a hard place here folks.
One last thing, found some high quality mechanic work when I pulled the timing covers off the donor. Pics bellow, enjoy.
Man, you've got some bad luck. Did you contact the guy you got that crusty engine from?
I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
The law does NOT determine "right" from "wrong". They are unrelated.
If you put cheap parts on your car, you will soon have a cheap parts car.
Use your current short block With rebuilt heads, is 1 option
and Alusil is not a coating
Do you have any other pics of the chain failure?
E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
In my post above I stated that option, unless you meant purchasing " rebuilt heads". If that's the case, I'm not sure they will be less then $400 a peice, so it would make more sence to rebuild the donor's heads by a guy who builds GT3 engines.
Ya I understand alusil is not a coating, not in the sence atleast. But the surface, created by etching and releasing the silicon can be removed like a coating, thus the reason why most assume it's an applied coating or call it a coating instead of " etched silicon surface ".
When I look into my cylinder I noticed the etched silicon surface was removed by friction.
I will have more photos of the failed motor when I remove it. Going to take a few days off due to frustration then get back too it with a plan of attack layed out.
Night an day difference between original motor and donor motor.
Does that usually happen when the motor isn't drained properly before storing?
