Results 1 to 19 of 19
Thread: installing immobiliser to e36 ( under construction)
    Sep 2003
    estonia
    92´325ic turbo, 07´335i coupe
    so you want to install immobiliser like this one?
    if you know how to solder wires then i think you will qualify
    step first
    open up fuse box, you will want to make thieves life as hard as possible.
    you need torx screwdriver. unscrew two front screws, be careful, apply pressure, do not break torx pattern on heads.also open drivers side under dash to get acess to wires and screws that hold fuse box in place. unscrew these 4 screws to get fuse box loose
    now you can get acess to fuse box rear screws. unscrew them carefully. open the box
    now its time to locate circuits that you will immobilise
    for example green/purple wire coming from fuel pump fuse (17)is ideal. measure voltage on wire( test light or tester one lead grounded):
    ign off- no voltage
    ign on- no voltage
    crank and run- +12
    when car running, cut the wire- if engine stops( after couple seconds), you have found right one.
    you can connect it temporarily together to locate another circuit
    after that connect it to immo as on its wiring diagram
    second circuit can be ignition for ecu
    it is green wire going from connection point to engine harness connector outside fuse box
    it has power when ignition is on
    if you cut it engine will stall immediately, remember that there are couple wires in that connector cut the right one, if you miss, connect back and be more careful next time
    now connect it to immo wiring ( connect now fuel pump wire too)
    remember power comes from ignition lock and goes to engine harness:
    twin wires for immobilising, third ignition sense for immo
    power up immo:
    red pernament power
    brown ground
    Sep 2003
    estonia
    solder all wires
    cut sharp edges
    isolate all connections
    locate drivers side door switch wire near drivers side speaker
    brown/gray/yellow
    never connect immo circuits on steering column. it is too easy to reconnect
    install led and antenna into center console. antenna can be located anywhere where you want, it does not work through metal
    Sep 2003
    estonia
    wiring diagram
    Jul 2001
    San Antonio, TX
    no BMW at the time
    sweet. It's up on the page now
    Ordered: '14 BMW M4
    Current: '08 Suzuki GSXR 1000; '08 HD Street Bob
    Previous: '06 BMW 330Ci; '06 Mercedes CLK-350; '04 Acura TL A-Spec; '95 BMW 318ti
    San Diego
    Harleys and a Tesla
    Re: installing immobiliser to e36 ( under construction)
    Uhh, what's an immobilizer?
    Feb 2004
    maryland
    98 bmw 323is
    nice write up man,,
    Thats why the call it"The ultimate driving machine"
    Lithuania, Kaunas
    bmw316
    Hallo,
    Somebody help me with bmw imobilaser instalation problem.
    Did anyone have an instalation manual for pat. No. 82929402597
    Jan 2006
    United Kingdom
    BMW Convertible E36 325i 1994
    nice write up cheers.
    Jan 2006
    United Kingdom
    nice write up cheers. I
    Jan 2006
    United Kingdom
    nice write up cheers. I knew
    Jan 2006
    United Kingdom
    nice write up cheers. I knew a
    Jan 2006
    United Kingdom
    nice write up cheers. I knew a guy
    Jan 2006
    United Kingdom
    Lawrenceville, GA
    4 BMWs.
    I thought the "code" feature on the OBC was an immobilizer....
    2001 Z3 3.0i -Oxford Green/Sandbeige
    2016 428xi -Estoril Blue II/Black
    2018 430iC- Estoril Blue II/Black
    2018 330it - Melbourne Red/Venetian Beige/Black
    FL
    are slow.
    pics plzz
    -Dr. Seuss
    Dec 2009
    Bowmanville, Ontario, Canada
    1995 BMW 325i
    Prague, Czech Republic
    e36 318is, e38 730d
    [ame]http://en.wikipedia.org/wiki/Immobiliser[/ame]
    Germany
    4x 325i E36, 1x M3 E92
    i just uninstalled that kind of immobiliser.
    but now, the car only starts when the drivers side-door is open(!).
    any ideas?
    Mar 2012
    newcastle nsw australia
    1995 BMW 318i
    Engine wont crank , battery ok
    My 95 E36 318i , has an immobilizer , I just found out when it refused to crank . The auto guy found that the small pink wire at battery positive connector was a bit corroded and after a wiggle it started fine , so there is an immobilizer and it runs from the little pink wire.(this is not my dumb logic , this was the advice of the road service guy)
