Results 1 to 9 of 9
Thread: dustless brake setup?
    Sep 2018
    Boston
    1988ica
    Didn't see much on here recently on brakes . I need new front rotors and was looking to upgrade to something cleaner . Any recommendations ?
    Jun 2015
    seattle
    1990 325i sedan M20 glac
    it's the particles of cast iron in the rotors that have a static charge from the heat causing the dust and from the pads alike. i think its unavoidable.
    akebono and hawk are good brands of pads advertising dustless..
    Sent from my LG-H872 using Tapatalk
    Jan 2019
    Evansville,IN
    87 BMW 325i Convertible
    i actually put powerstop on mine with ceramic pad and slotted and drilled rotors. I see very little brake dust with this setup and will stop on a dime. I have used powerstop on several vehicles with great success.
    1987 BMW 325i Convertible
    “Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
    Jeremy Clarkson
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    My factory pads were very dusty. The replacements are not but I don't remember what they are. If you look at Rockauto, some of the pads say low dust.
    Apr 2020
    Bering Sea/Spokane Wa.
    1990 325i vert
    Quote Originally Posted by 88325ica View Post
    Just make sure you buy ceramic brake pads. Your rotors aren’t the problem, it’s the material used in the pads that create the dust. I’ve done this on all of my cars and now I don’t have to clean my wheels every day.
    Quote Originally Posted by doctorx69 View Post
    Curious as I’m looking into the exact same set up. Did you do front and rear with the power stop? Also, did you replace the calipers with power stop as well? I’m looking at the packages available through Rockauto and I’d appreciate your feedback.
    Jul 2003
    nova
    8 BMW's & a Ford p/u
    slotted/drilled rotors are just eye candy on a street car and don't improve braking. they also cause more dust and pad wear as the edges shave the pads off.....
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    but at the autocross those slotted rotors are great. I kept cracking solid rotors, in the rears. once I swapped to slotted, no more cracks
    No e30s again.
    Jan 2019
    Evansville,IN
    Quote Originally Posted by mlytle View Post
    uh... ok... i guess my experience is different than yours. Helps a bunch with panic stops. And i still do not have much dust. With about 2000 miles on the brakes, still have a bunch of pad left.
    Quote Originally Posted by CRABKLR View Post
    did front an rear pads and rotors. I did buy new calipers, but i dont think they were powerstop.
    Jan 2019
    Evansville,IN
  1. dustless brake pads?
    By dinan3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-19-2006, 06:40 PM
  2. Track brake setups
    By Saint in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-12-2003, 01:57 PM
  3. Let's hear your brake setup
    By John (PA) in forum Forced Induction
    Last Post: 01-20-2003, 07:41 PM
  4. Need a brake setup worthy of F/I
    By Icecream ///Man in forum Forced Induction
    Last Post: 01-13-2003, 10:51 PM
  5. Is it normal for new brake setup to squeal?
    By vroo//M in forum 1992 - 1999 M3 (E36)
    Last Post: 07-09-2001, 11:18 AM
