My tyres are 255/30zr19 and 235/35zr19 I normally just get to 36psi on both front and rear would guys recommend any different psi to front and rear
Car is 325ci 2001
Any psi specs on the sidewall?
Hey! Im far from an expert but what I usually do is put 40psi in rear and 38 in the front. I have 275 30zr19 and 245 35zr19
Ditto ... been doing that for years ... regardless of vehicle ... use the recommendation inside the driver's door and add 2 lbs.
The psi rating is displayed on tire sidewall.
Do not go on the rating on the tire. That is maximum PSI only. Go off the drivers side door jamb. For a little better handling 2 PSI more is good. Anymore and you will end up hurting performance and wearing the tires quicker in the middle.
If I can help let me know.
