Hi. I have a 2015 74li, white with a msport body package. Today on the front bumper a part (appears to be some kind of small cover) came off and cannot be found. I need help with the part name. It’s round and on the right side of the bumper.
Moved to F01, F02 forum from 7 general forum.
pls add to your profile exact model, built year and months, helps us to help youMy Cars: 740li
Use BMW parts catalog to find the part number , there you also find the production month and year of the car with your VIN http://bmwfans.info/parts-catalog
It's probably the tow hook cover. It will need to be painted when you buy it.
Sounds like you need item #2 in the diagram below. Click the link and scroll down to the part nbr index to get the 11 digit BMW part nbr to order it. As stated above, it comes primed and you'll need to get it painted...unless you search for a used one with the same color exterior paint you have. Again, you'll need to search using the correct 11 digit BMW part nbr for the type of bumper you have, and use the correct BMW paint color code so that it kind of matches.
BTW, I'm also assuming that you're in GEORGIA (the country) and not the southern state in the USA. If not, if you have the M bumper...the part nbr will be the same.
