Hi the chirping sound is not working anymore... The key fob still works and all I hear is the sounds of the actuator unlocking/locking... I did leave the car unlocked for an extended period of time because I was diagnosing my slave cylinder so im guessing that caused it to not chirp anymore. I really need this chirping sound again for the safety and making sure my car alarms when someone is trying to break into my car... Please HELP!!! Do i have to buy another siren or did my battery in my siren go out because i left my car unlocked too long?
RECAP: KEY FOB STILL WORKS W/ UNLOCKING/LOCKING CAR AND WHEN ITS IN PANIC MODE, THE HAZARD LIGHTS BLINK CONTINUOUSLY.
Moved from E36 forum to E36 M3 forum
So everything works except the sound? Make sure the cable is still plugged into the siren under the hood before you go nuts ripping stuff apart to source the issue
Please restate your problem. DO you have a BMW alarm?
Your car does not chirp. Well does it lock the doors? Does the alarm go off if you tamper with it? Like open the door without pressing the alarm to deactivate?
What is this panic mode? All it does it set off the alarm... or does it just unlock the doors since you hear no noise?
What is HAZARD LIGHTS BLINK CONTINUOUSLY. ??? they only flash when activated or deactivated. if they flash all the time then you may have a alarm problem.
Battery on remote does not affect alarm sound. The alarm does not have it own battery normally. If you did drain the car battery Then your alarm setting may be reset or erased. Leaving the alarm off does not erase the siren.
The siren is just a fancy speaker with tiny voice coil wires. They can break Thus the question check your wires.... Measure the siren wires for voltage as you activate the alarm or attach a light bulb and look for a flash. Then probably get a new $15 siren
And yes there is a setting to silently activate and deactivate the alarm when you do not want to disturb the neighbors.
Yes it is the OEM alarm system! everything works except the chirping sound aka the siren. It was working a few days ago now its not giving out the sound! When it used to work, it gives one chirp for lock and 2 chirps for unlocking. How do I get that chirping sound back because when I activate the alarm by holding down the LOCK button which triggers the siren to go off, the signal lights blink along with the siren but no there is no sounds whatsoever. Even unlocking or locking the car, all i hear is the sound of the actuator.
The chirping sound can be disabled via the remote by pressing the two buttons together for a duration. It is covered in the users manual.
BMW Alpine 2-Button Keyless/Alarm Install Directions - http://photo.msportparts.com/E36/Doc...rm_Install.pdf
BMW Alpine 2-Button Keyless/Alarm User Manual - http://photo.msportparts.com/E36/Doc...ser_Manual.pdf
If that doesn't resolve your issue, the OEM Alpine sirens have the blue and gray wires coming off of them. For whatever reason, underneath the taped on electrical sheathing, you'll find that they use a butt connector to extend the wires to the BMW siren connector. It is common for that butt connector to fail. Inspect the full wire length on the siren side (not the car side).
^ This.
I've had my car for ten years and just found out that I could turn the chirping ON. I was never sure it locked if I wasn't close enough to hear the locks (even though they're loud, in noisy environments it can be tough to hear from very far away). I just held both buttons down until it chirped like it does when you don't have the door closed (that was the only time it chirps if it's turned off).
Actually, that's not a bad way for you to test it - leave a door open and try to lock it. You'll get three chirps if it's still functional.
No chirping sounds like a win. Both for you and whomever might be around and have to listen to it. The doorhandle is always a good test to see if it's locked if you can't hear it.
98 328is
02 525ita
80 528i
81 528ia
and decades of owning and driving BMWs
Have you done something simple like trigger the alarm to see if it's the siren itself or if it's just the chirp that's off?
It will chirp three times if you try to lock it with the door open, even with the chirps turned off. Or just lock it with the remote and unlock it with the key and open the door.
Did you solve this? I have a factory fitted BMW alarm system (Key Fob has 1 button only) and just today I had the same problem as you, hence I googled and found this thread. Everything works: Key fob, it locks/unlocks, led indicator, if the alarm is triggered - the siren sounds & hazards blink. EXCEPT, it has stopped chirping when lock/unlock. Used to chirp once/twice when lock/unlock however now it's silent. However, the signals flashes when lock/unlock. Any fixes to the chirps?
As far as I'm aware the factory alarm does not flash ANY signal lights when locking / unlocking - just when the alarm is activated.
However, my car has a 2 button alarm, so it's possible older alarms with a different remote also function differently.
