Results 1 to 18 of 18
Thread: hood vent water temperature difference
    Aug 2012
    Central, MD
    1995 M3
    Those of you that have installed hood vents on an E36, what water temp difference did you see, if any?
    Jan 2014
    Mobile, AL
    2017 Raptor 97 M3 02 M3
    Quote Originally Posted by aeronaut View Post
    I was running temps ~220 degrees at the end of track sessions in the summer in new orleans. after my HG went (after 3 years of tracking) I installed a lower temp thermostat, mishimoto fan kit, smaller water pump pulley and track spec hood vents. I did an event last weekend. air temps were around 95degrees. My coolant temps were around 185 during the whole day. I think all of it helped but i can see heat radiating out of the hood vents. I know its helping to get air out.
    Aug 2012
    Central, MD
    1995 M3
    Good info, thanks.
    My water temps aren't out of hand (~220 ish or less at end of session). But my hood is f'd up anyway, so there's no mental barrier to cutting holes in it.
    Oct 2007
    Louisville, KY
    1995 M3
    I want to do this too for a little extra insurance. I see the big center vent helping, but what would the side vents?
    Oct 2005
    Nördlich des Äquators
    M3TTst2Meth-K1300S-1100G
    I did it too and AFAIK the engine bay is being pumped up while driving at speed so any openings in the hood will help evacuate hot air.
    I did the coyo rad at the same time + oil cooler and had major cooling effect (mainly the coyo rad) .
    Another benefit of hood vents may be less aero drag and more down-force.
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by bimmerboy318 View Post
    I'm not sure it would make a ton of difference (side vs center vents). That said, I believe the side vents can be put in without removal of hood bracing. The center vent is right were there is significant bracing. If that matters.
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    I am a firm believer in huge hood vents. Placed in a low pressure zone, they can only help and my experience has been wonderful with temps. Running 400whp/wtq at 185 degrees under full bore.
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by olemiss540 View Post
    Sweetness!!
    Ok, magic sauce.....center? Sides? Any will work, or must be...where?
    Springfield, IL
    I did the largest I could find (vraptor I think its called?) Center and sides. Do us all a favor and make no other changes so we can all compare your temps!
    Aug 2012
    Central, MD
    1995 M3
    If I do, I will!
    Oct 2005
    Next chance I get I will run a few laps with vents taped shut and then open them. Same ambient temp , same track, same engine load...should give real results
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by Haifisch M3 View Post
    Great idea, and awesome!
    Springfield, IL
    That's an awesome idea. Please please please follow up!
    Mar 2006
    Crystal Lake, IL
    332TI, '06 330 XI
    Did you ever do this test??
    Aug 2003
    Dallas, TX
    Z3M, X5M
    Would removing the fan shroud help in bring down my coolant temps on the track? I'm running an lower temp thermostat and oil cooler. Aux fan and AC condenser were removed.
    -Phil
    Springfield, IL
    Quote Originally Posted by Z-Thrizzle View Post
    Almost certainly. Poorer performance in traffic at slow or stopped speeds but removed mine as at speed it is nothing but a restriction. My car with no shroud (spal fan mounted direct to radiator) and hood vents almost runs too cool!
    Oct 2005
    turbo m3
    taped the vents shut, did back to back laps and after 5 laps
    the highest coolant temp was:
    192 with vents
    198 with vents taped shut
    only 6 degrees but ambient temp was in low 70s...in warmer weather it might be more
    Aug 2012
    Central, MD
    1995 M3
    I just ran a high-rpm track (some 2nd gear stuff, low average speed, etc) with 96 deg air temps (who knows what the track temps were).
    Similar conditions last year, I was seeing 225 mid -session.
    This year, the highest temps I saw were 215.
    Also, on skid pad: (high rpm, lowwww speed).
    Last year, I was limited to 2-3 min sessions because water temps would have reached 225 quickly.
    This year, water temps stayed below 210.
    I'm convinced, 10 deg improvement minimum. I'd bet 15deg on average.
  1. Hood vents /water drainage
    By Breeze1 in forum 1983 - 1991 (E30)
    Last Post: 07-02-2018, 08:45 PM
  2. Vented Hood and Water Ingestion
    By sirzepp in forum Forced Induction
    Last Post: 02-08-2010, 03:45 PM
  3. Water leaking in the 2 hood vents under the wipers.
    By tristan714BMW in forum 1983 - 1991 (E30)
    Last Post: 06-16-2009, 07:30 PM
  4. Hood Vents and Water
    By wolffbimmer in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-12-2009, 07:58 PM
  5. Replies: 0
    Last Post: 04-17-2003, 06:47 PM
