Those of you that have installed hood vents on an E36, what water temp difference did you see, if any?
I was running temps ~220 degrees at the end of track sessions in the summer in new orleans. after my HG went (after 3 years of tracking) I installed a lower temp thermostat, mishimoto fan kit, smaller water pump pulley and track spec hood vents. I did an event last weekend. air temps were around 95degrees. My coolant temps were around 185 during the whole day. I think all of it helped but i can see heat radiating out of the hood vents. I know its helping to get air out.
Good info, thanks.
My water temps aren't out of hand (~220 ish or less at end of session). But my hood is f'd up anyway, so there's no mental barrier to cutting holes in it.
I want to do this too for a little extra insurance. I see the big center vent helping, but what would the side vents?
I did it too and AFAIK the engine bay is being pumped up while driving at speed so any openings in the hood will help evacuate hot air.
I did the coyo rad at the same time + oil cooler and had major cooling effect (mainly the coyo rad) .
Another benefit of hood vents may be less aero drag and more down-force.
I am a firm believer in huge hood vents. Placed in a low pressure zone, they can only help and my experience has been wonderful with temps. Running 400whp/wtq at 185 degrees under full bore.
I did the largest I could find (vraptor I think its called?) Center and sides. Do us all a favor and make no other changes so we can all compare your temps!
If I do, I will!
Next chance I get I will run a few laps with vents taped shut and then open them. Same ambient temp , same track, same engine load...should give real results
Would removing the fan shroud help in bring down my coolant temps on the track? I'm running an lower temp thermostat and oil cooler. Aux fan and AC condenser were removed.
-Phil
turbo m3
taped the vents shut, did back to back laps and after 5 laps
the highest coolant temp was:
192 with vents
198 with vents taped shut
only 6 degrees but ambient temp was in low 70s...in warmer weather it might be more
I just ran a high-rpm track (some 2nd gear stuff, low average speed, etc) with 96 deg air temps (who knows what the track temps were).
Similar conditions last year, I was seeing 225 mid -session.
This year, the highest temps I saw were 215.
Also, on skid pad: (high rpm, lowwww speed).
Last year, I was limited to 2-3 min sessions because water temps would have reached 225 quickly.
This year, water temps stayed below 210.
I'm convinced, 10 deg improvement minimum. I'd bet 15deg on average.
