Looks like I may be in the market for a new one, as my current one leaks. It looks as though its leaking from the windshield washer pump area. I've searched realoem, and it looks as though mine would be the one w/ the headlight washer system; even though I don't have headlight washers. Is it possible that would be the same, since tourings have the rear wiper?
Probably only needs a new rubber gasket for the pump. Also, check the hoses.
Agree it's not the bottle
No. Description Supp. Qty From Up To Part Number Price Notes 01 Fluid container with level indicator 1 10/2000 61677044898 $52.60 02 Gasket 1 61671378631 $0.80 03 Wash pump for head lamp cleaning device 1 09/1997 67128377430 $69.57 04 Rubber grommet 2 61311369343 $1.93 05 Levelling switch wash container 1 61318360459 $32.46 06 Ventilation valve 1 06/1998 61608255245 $2.43 07 Strainer for washer pump 2 09/1997 61667006063 $2.62 08 Wash pump windshield (Front and Rear and INTENSIVE) 2/3 09/1997 67128362154 $42.75 09 Grommet 1 61668360138 $0.75
If you have headlamp washers, rear washer (if you have a wagon you got it), windshield washer, and if you have the little bucket under the hood (that is called Intensive) The button on end of your washer stuck turns it on.
Leaks; Little washer under the pump 61667006063 #1 issue
Pump it self leaks #2
Lines popped due to no winter washer fluid being used #3
Rotted lines #4
large refill hose leaking at tank #5
Current Garage Highlights
2003 525iT TiSilver
2002 M5 TiSilver
Former Garage Highlights
2005 X5 4.8is
2004 325iTs (2x)
1973 Pantera L
1969 Road Runner 383
If it is both the rubber O ring and the washer pump - buy the VDO ones as that is who made the OE ones. One part number for both units stuck in the side of your reservoir, which is hidden under the RF fender splash shield. Take off the tire, pop the rivets and little screws, and presto it is mounted to your left (between the tire and the passenger door)
DIY instructions
https://www.bimmerforums.com/forum/s...rvoir-Leak-Fix
2003 525iT TiSilver
2002 M5 TiSilver
2005 X5 4.8is
2004 325iTs (2x)
1973 Pantera L
