Very curious how the wiring went with that n62 setup and the oem gm stuff. Building out my list of parts for this build, 108*+ deg ambient in the summer.
We demand updates mr Bluebimma.
Been a long while since the last update soooooo, enjoy.
Transmission upgrades
Crank drilled and pinned for premature failure
Fan setup changed
Removed the OE tensioner for a manual unit from ICT Billet
Ordered a 1200hp Capacity Air to Water intercooler
Air to water heat exchanger installed
More transmission upgrades!
2001 E53 X5 - 5.3 Procharged, 4L80E RWD, Brembo, 20" alloy, EBC race, Forge, A2W intercooled, Alcantara interior, 3.62 LSD and more!
2005 E53 X5 - 6.0TT, 4L80E RWD, 20" alloy, EBC race, Forge, A2W intercooled, Alcantara interior, 3.62 LSD and more!
1996 E36 335ti - N54b30, A2W intercooled, ZF 6speed rwd, 4.10Lsd, Speedline magnesium rims, Brembo, S55 exhaust, 245/40/17-295/30/18, idrive, Forge, logic 7
1999 E36 360ti - 6.0, ls6 springs, ls6 cam, hardened pushrods, trunion, racing baffle, t56, ls7 clutch, m3 brakes, 4.10lsd
oh dang those control arms are a really nice kit. Pretty sweet to see alfa romeo calipers. Good update with alot of goodies for the car.
Purchased and installed an ICTbillet ac/c compressor adapter plate kit. bolted in perfectly. The hoses also aligned properly and bolted back in.
Installed the brembos, fit nicely. Running a square setup, it doesnt need spacers in the front, however if, i run staggered, it needs a 15mm spacer minium
What are the Brembos off?
2002 BMW 525i - 6.6L LS Turbo Swap
Follow me on Instagram at @LantzFab
Link to LantzFab.com
Link to my Facebook page
Link to my build page
Perfect timing! I am just about to buy that bracket. I just went to the Pick and Pull and nabbed a compressor from an E46.
I am trying to figure out my hose situation. Just to make sure I understand, you used the original hoses and compressor from the E53? Are you doing anything to get a GM pressure sensor on the system?
Diving in at the shallow end!
Picked up some used F82 380mm rotors this past week. They seemed to have matching specs and even negating need the original spacer adapters i made. Reduced 7lbs per rotor, 32lbs recorded from the range rover, with this setup. The f82 rotor is also .6lbs lighter than the stock 3.0, 6lbs lighter than the 4.6is 355mm rotor. Ordered 2001 range rover sport front hoses, look like a direct fit as well.
Maybe it’s just me, but it appears your images got the axe!
Yeah lots of pics down unfortunately
Photo bucket taking a shit again. Their services are so subpar nowadays. It’s so pathetic considering most people have migrated simply to Instagram and Facebook.
Sent from my iPhone using Tapatalk Pro
what salvage yards do you pick from around Detroit? I'm in the area.
Any that have what i want.
Photobucket is sucking hard, now theyre out of sequence
