Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 86
Thread: Bluebimma Project - E53 5.3T Procharged 5.3/4l80E/3.62LSD
  1. #26
    Jul 2006
    335ti 360ti x5-6.0tt
  2. #27
    Jul 2006
  3. #28
    Jul 2006
  4. #29
    Mar 2019
    Milwaukee, WI
    '99 LS-swapped 323i vert
    Oh hell yeah!
    Diving in at the shallow end!
  5. #30
    Jul 2006
    Pulled the procharger assembly off to do final torque, paint, and installation of parts. The power steering reservoir has been highly modified and extended to insure the ability to fill the system without funnels and frustration. The extension housing has also been tapped and plumbed up to .5" for the return of fluid from the supercharger. The superchargers' bearings and gears will be lubricated with cooled ATF fluid fed from the power steering system. The system will feed the supercharger on a tee and return the remainder of the fluid back to the lower portion of the reservoir to feed the rack and continuously feed back into to the cooler and top side of the supercharger.
  6. #31
    Jul 2006
  7. #32
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    You're an animal dude!
  8. #33
    Jul 2006
  9. #34
    Jul 2006
  10. #35
    Washington
    BMW 525i
    Looks like we are getting close to drive video!?
    2002 BMW 525i - 6.6L LS Turbo Swap
    Follow me on Instagram at @LantzFab
    Link to LantzFab.com
    Link to my Facebook page
    Link to my build page
  11. #36
    Jul 2006
  12. #37
    Jul 2006
    Started sorting out the wiring for the engine bay. Deleted the rest of the BMW side DME and trans computer, routing the correct lines to the GM side to power that PCM and fuse box. Repinned the GM Pcm to convert to electronically controlled fans while deleting the viscous fan.
    Installed 20mm spacers on the front and 25mm spacers on the rear. I think this is the setup i want to run. Itll also let me run my brembo brakes with the OEM 20" rims
  13. #38
    Jul 2006
  14. #39
    Jul 2006
  15. #40
    Jul 2006
  16. #41
    Jul 2006
  17. #42
    Jul 2006
  18. #43
    Jul 2006
    More fit and finish happening. Cut up a lot of the plastics for the vanity cover. The cowl had to be heavily modified as well to fit the new engine. The wiring is 95% done, just waiting on the new arduino to come in and fit to the engine bay. Had an issue with the power steering pump going into full time relief. Found a piece of plastic in the pressure valve. Removed the debris , polished the valve and shimmed the spring. Next to fit the engine oil cooler and the new transmission cooler. Also had the 105amp alternator take a dump on me so i installed the 145amp from the escalade.
  19. #44
    Jul 2018
    Louisiana
    Bmw E39 528i
    Awesome stuff, I want the same head unit. Are those rad fans from amazon? I have two 80w ones from amazon that look just like those. How good of a job do they do coolin down the v8? I haven't tested mine out yet.
  20. #45
    Jul 2006
    Quote Originally Posted by mrallande5020 View Post
    Theyre just the generic ones you can find on ebay and such. I have them on my 360ti as well and they work fine. ive ran them from ohio to death valley and through the mountains with zero issues.
  21. #46
    Jul 2006
  22. #47
    94 325i, 95 M3, 1997 325
    Sweet Jesus dude this thing is going to be amazing
    Washedit1 by thedude60526, on Flickr
    11/10's Racing
    94 325i #36/64 TEAM PENISTON OILS/ LARSENS BISCUITS
  23. #48
    Dec 2009
    Detroit
    E36 Compact,Coupe,E30
    give us an update and yo pics dont work. FIX IT
    S52 E36 Compact
    E36 325is Coronaproject
    08 Saab 9-3 in Oxford Green
  24. #49
    Dec 2013
    Fort Wayne, IN
    Not sure
    This build is spectacular.
    I noticed in another BMW E53 build you commented the below
    Quote Originally Posted by Bluebimma
    It is easy to keep 4x4. I wouldnt keep AWD, id do the 4x4 push button transfer case and front standalone differential from the silverado. itll fit with custom axles very easily
    Would you start off with a 4x4 E53 or would it be easier to start with RWD and do the AWD from scratch? Obviously, just a thought experiment but man...an LS swapped 4x4 E53 would be a badass kid hauler. I have an E61 right now and know how tied together everything is in that car. Would be curious if the E53 systems are more independent.
  25. #50
    May 2001
    Plymouth, MI 48170
    1999LSxSwapped 557i & X5
    Quote Originally Posted by Azar View Post
    All X5's are AWD. Thats what the X stands for.
    E53 LSX Swap Coming Soon!
  1. *E53 2002 BMW X5 4.6is Silver/Imola RWD LSX Project*
    By Bmwman528e in forum Engine Conversions
    Last Post: 12-24-2023, 03:59 PM
  2. Bluebimma Project 335Ti CSR
    By Bluebimma in forum Engine Conversions
    Last Post: 12-21-2022, 04:17 PM
  3. Blackknight530i has another new non-E39 project (E53 X5 4.8is)
    By blackknight530i in forum E39 Hangout
    Last Post: 05-16-2022, 09:59 PM
  4. Bluebimma Project E53 6.0T
    Last Post: 05-06-2019, 09:17 PM
  5. The 2004 E53 Project!!
    By william540i in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 03-30-2016, 11:09 PM
