2001 E53 X5 - 5.3 Procharged, 4L80E RWD, Brembo, 20" alloy, EBC race, Forge, A2W intercooled, Alcantara interior, 3.62 LSD and more!
2005 E53 X5 - 6.0TT, 4L80E RWD, 20" alloy, EBC race, Forge, A2W intercooled, Alcantara interior, 3.62 LSD and more!
1996 E36 335ti - N54b30, A2W intercooled, ZF 6speed rwd, 4.10Lsd, Speedline magnesium rims, Brembo, S55 exhaust, 245/40/17-295/30/18, idrive, Forge, logic 7
1999 E36 360ti - 6.0, ls6 springs, ls6 cam, hardened pushrods, trunion, racing baffle, t56, ls7 clutch, m3 brakes, 4.10lsd
Oh hell yeah!
Diving in at the shallow end!
Pulled the procharger assembly off to do final torque, paint, and installation of parts. The power steering reservoir has been highly modified and extended to insure the ability to fill the system without funnels and frustration. The extension housing has also been tapped and plumbed up to .5" for the return of fluid from the supercharger. The superchargers' bearings and gears will be lubricated with cooled ATF fluid fed from the power steering system. The system will feed the supercharger on a tee and return the remainder of the fluid back to the lower portion of the reservoir to feed the rack and continuously feed back into to the cooler and top side of the supercharger.
You're an animal dude!
Looks like we are getting close to drive video!?
2002 BMW 525i - 6.6L LS Turbo Swap
Follow me on Instagram at @LantzFab
Link to LantzFab.com
Link to my Facebook page
Link to my build page
Yea getting close for sure
Sent from my iPhone using Tapatalk Pro
Started sorting out the wiring for the engine bay. Deleted the rest of the BMW side DME and trans computer, routing the correct lines to the GM side to power that PCM and fuse box. Repinned the GM Pcm to convert to electronically controlled fans while deleting the viscous fan.
Installed 20mm spacers on the front and 25mm spacers on the rear. I think this is the setup i want to run. Itll also let me run my brembo brakes with the OEM 20" rims
More fit and finish happening. Cut up a lot of the plastics for the vanity cover. The cowl had to be heavily modified as well to fit the new engine. The wiring is 95% done, just waiting on the new arduino to come in and fit to the engine bay. Had an issue with the power steering pump going into full time relief. Found a piece of plastic in the pressure valve. Removed the debris , polished the valve and shimmed the spring. Next to fit the engine oil cooler and the new transmission cooler. Also had the 105amp alternator take a dump on me so i installed the 145amp from the escalade.
Awesome stuff, I want the same head unit. Are those rad fans from amazon? I have two 80w ones from amazon that look just like those. How good of a job do they do coolin down the v8? I haven't tested mine out yet.
Sweet Jesus dude this thing is going to be amazing
Washedit1 by thedude60526, on Flickr11/10's Racing
94 325i #36/64 TEAM PENISTON OILS/ LARSENS BISCUITS
give us an update and yo pics dont work. FIX IT
This build is spectacular.
I noticed in another BMW E53 build you commented the below
Would you start off with a 4x4 E53 or would it be easier to start with RWD and do the AWD from scratch? Obviously, just a thought experiment but man...an LS swapped 4x4 E53 would be a badass kid hauler. I have an E61 right now and know how tied together everything is in that car. Would be curious if the E53 systems are more independent.Originally Posted by Bluebimma
