Results 1 to 4 of 4
Thread: Help - ME7.2 DME 540i M62 Boot Mode bin Dump
    May 2019
    Canada
    E39 Touring
    Hey Guys.
    Trying to get a 512kb dump off my ME7.2 ECU - I have put together a bench harness and am using JMGarageflasher to pull the .Bin File.
    JMGarageflasher mentions to connect the following pins.
    POWER
    • X60001
    • PIN 1,2,7,8,9
    Ground
    • X60001
    • PIN 5,6
    K-Line
    • X60001
    • Pin 3
    And ground the 8th solder point on the ciruitboard.
    as per-
    (http://jmgarage.ru/bosch-me-7-2-bootmode-programming-2/)
    Doing so Doesn't allow me to Connect to the ECU!
    Upon looking at the following diagram it appears I need to connect a few pins on connector x60004
    - OBD Pin 7 (K-Line) connects to X60004 Pin 32 -- Instead of suggested Pin 3?
    - OBD Pin 9 connects to X60004 Pin 17 (unsure of the function of this)
    The DME came from a 2001 6spd but the diagram shows something about A/T 4.4 for Pin 32.- Unsure but know that AGS isn't a thing.
    So I tried it this way and I'm able to pull a BIN from the ECU if I have pin 32 connected as the K-Line ....but not if the Pin 16(OBD2) - Pin 17(X60004) is connected.
    However now when I open it in Tuner Pro to check the version it comes up with Y with colons ontop (ÿ). - same with when I check INPA.
    Anyone know what I'm doing wrong?
    If someone wants to hold my hand through this I'd be happy to Paypal you haha. I'm not fully inept I think I just need a little guidance - ehrm geargrinder zarbov cough.
    Jun 2018
    Castle Rock CO
    1990 325is, 1998 740i
    I can help you out man shoot me a dm
    when i get home i can take pics of the bench setup i use or basically how I do it in the car is to take Dme shield off and ground the boot pin with a piece of wire tack soldered to the boot pin and wrapped around a body ground
    put key into ignition and then to position 2 hop out count to 5 and remove the boot pin wire from ground
    go to laptop on jmgarage flasher and click connect then read
    Also the UIF entries are blanked on the flash I have from DUDMD so it looks the same as what you posted
    do any of your tables look proper?
    Also if you took a boot dump your UIF numbers are written i THINK around 1FF80 ~~ somewhere towards the bottom fo 10000>1FFFF
    The Tunerpro files are written around a 64kb dump so unless you offset the file in the tunerpro settings you wont be viewing an accurate hex region for the UIF entries
    I like to pretend I know stuff
    May 2017
    Poland
    e30
    Quote Originally Posted by iamshayan View Post
    Hey Guys.
    POWER
    • X60001
    • PIN 1,2,7,8,9
    Ground
    • X60001
    • PIN 5,6
    K-Line
    • X60001
    • Pin 3
    as per-
    Can't see x60002 -> Pin 23 +12v (DME Relay) in You'r setup.
    Also edit xdf info parameters and make Offsett 10000 if You are using 64kbit xdf with 512kb file.
    My Setup which works all time:
    x60001:
    Pin 7,8,9 = +12v
    Pin 5,6 = Ground
    x60002:
    Pin 23 = +12v (dme relay)
    x60004:
    Pin 26 = +12v (dme supply voltage)
    Pin 32 = K-Line
    make sure to apply ground to bootpin and then power up dme, still with bootpin click connect @ jmgarage.
    ganesht's Avatar
    ganesht is offline (oOO)\(lll)°(lll)/(OOo) BMW CCA Member
    Sep 2008
    san diego, ca
    98 528i 5 speed
    For anyone having issues getting their me7.2 into boot mode, you just need x60001 12v, gnd, k line. You need to ground the boot pin for 2-3 seconds, if you do the 5+ seconds listed elsewhere it wont work.
    Alida:
    Born: Friday, 9th January 1998
    Arktissilber Metallic on Schwarz 528i/5
    Claudia:
    Born: Friday, 2nd May 2003
    Sterlinggrau Metallic on Schwarz 540i/6
  1. E39 540i M62 rough shaky idle - HELP!
    By BayernKiwiBMW in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-13-2009, 08:54 AM
  2. 540i Shift Boot? please help
    By gjVah in forum 1996 - 2003 (E39)
    Last Post: 02-05-2009, 01:50 PM
  3. HELP NEED DME stock chip
    By M3D in forum California sponsored by Avus Autosport
    Last Post: 08-07-2003, 06:49 PM
