Results 1 to 6 of 6
Thread: BMW e39 520i M52b20 - clutch change
    Jun 2019
    Bulgaria
    e39
    • Hello today I will show you a change of BMW clutch e39.
    • First, disassemble the battery cables. Wrench 13mm.
    • I dismantle the cover under the engine and the gearbox.
    • Here I undo the two 13mm clutch nuts on the clutch pump I also unbuckled the reversing sensor jack.
    • I dismantle the exhaust system and the shield above it to get better access to the driveshaft and the bearing.
    • Unscrew the Flex disc and Driveshaft Center Support bolts to be able to remove the driveshaft from the gearbox. The driveshaft bolts and nuts are 18mm and drive center support 13mm.
    • Remove the gearshift gear lever, push the pins up and pull it to the left. Sometimes he nails wildly. The other lever only removes the pin and pulls the lever.
    • Then remove the two starter bolts.
    • I dismantle the remaining seven - eight bolts, and there is a small bolt of 10mm, which is obligatory to develop if I want to remove the gearbox. There are also six bolts of 13mm that hold the box stand.
    • This is already the clutch I have to change.
    • With the clutch, disassemble the flywheel to see the condition of the crankshaft sealing under it.
    • After replacing the sealing preventively, I mounted the flywheel that I fastened with 120Nm and a threaded lock. The bolts were 18mm.
    • Here I have mounted and centered the new clutch I am tightened with 32Nm.
    • We mount everything on the way back, and if it's okay for three hundred miles an hour, we go to the beer store. This is the whole procedure. Bye and next time.
    New blog for repair and engagement of all types of cars https://mechanicus89.blogspot.com/
    Aug 2016
    Sydney Australia
    E39 530i, Ford Territory
    Nice thread & nice gearbox jack.......just wondering if you support the rear of the engine or are the engine mounts good enough to hold it without stressing them to much?
    Jun 2019
    Bulgaria
    e39
    There is no problem of shaking, so far there was no problem
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    You need to revise the battery disconnect part. For safety reasons always disconnect the negative lead first.
    If your wrench hits any metal it could weld itself to the metal which could blow up the battery.
    Jun 2019
    Bulgaria
    e39
    In this case you are right because the battery is in a bad place, but for the other places I prefer to always remove the positive cable. Otherwise, a short circuit is required to get the battery over.
    Jan 2015
    Shreveport Louisiana
    he beat me to it...as usual. the open end part of the wrench is just a hair from shorting to ground. if it rocks on the nut, el sparko grande.
  1. BMW e39 520I Burning oil.
    By athaaj01 in forum 1996 - 2003 (E39)
    Last Post: 04-16-2015, 05:50 PM
  2. Replies: 0
    Last Post: 02-25-2015, 07:43 PM
  3. BMW E39 520i ~ My Pride & Joy
    By HAHA AMG in forum BMW Rides & Events
    Last Post: 12-03-2014, 11:25 AM
  4. BMW E39 520i ~ My Introduction
    Last Post: 11-26-2014, 12:15 PM
  5. bmw e39 m5 UUC clutch kit for sale
    By Punisher in forum 2000 - 2003 M5 and Z8 (E39, E52)
    Last Post: 09-05-2013, 12:01 PM
