Results 1 to 17 of 17
Thread: New Hella Xenon Lights Keep Flickering and Going Out
    Aug 2018
    Orlando, FL
    2002 BMW 525i
    Question New Hella Xenon Lights Keep Flickering and Going Out
    I changed out my old headlights to Hella Xenon headlights and have has issues since. They keep flickering and going out while driving and it is very frustrating. I have checked bulbs and they look fine, I have tried three different ballasts and they all give me the same issue. I have tried coding xenon in using NCS Expert and cannot find the option to turn them on. I modified my SA number to include $522 but I see no option still for xenon/bi-xenon. I really need help finding out what the issue is its been driving me insane for months. My previous headlights did not give me these problems.
    Jaaap is offline ☀ ☁ ☂ ☃ ☏ ☠ ☢ ☣ ♕ ♫ ✂
    Jun 2008
    Belgium
    Alpina B10 e39 / F3
    You need to code the LCM asap.
    The cold monitoring wil kill the xenons quickly (also you turning the headlights on and off repeatedly will kill xenons quickly).
    Disconnect the xenons, code the LCM.
    Edit: iirc, not all LCM's can do xenon lights. Perhaps you need a different LCM.
    Aug 2018
    Orlando, FL
    2002 BMW 525i
    What do you mean by disconnect the xenons? Unplug the ballast or take out the bulbs?
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Unplug the ballasts, what LCM does your car have, code your current LCM module properly, did it already have HID’s before, why were you turning the lights on and off ???
    Dec 2012
    Philly Suburb
    2002 BMW 540iA
    I see you have trifecta lights on.
    Aug 2018
    Orlando, FL
    2002 BMW 525i
    Quote Originally Posted by theWalkinator View Post
    steering angle sensor fault
    I've turned off all my cold monitoring for high/low beams, turn signals & fogs.
    Attachment 654506
    San Jose, CA
    1997 BMW 540i 6 speed
    I installed these. You may need to do this: https://www.hidnation.com/collections/hid-accessories/products/hid-cancellers
    I extended the leads so I could mount them in a convenient spot.
    Aug 2018
    Orlando, FL
    2002 BMW 525i
    Quote Originally Posted by edjack View Post
    says 404 page not found
    San Jose, CA
    Aug 2018
    Orlando, FL
    2002 BMW 525i
    I tried using the cancelers I used on my previous lights, Sure enough after 5-10 minutes my driver side lowbeam went out.
    Aug 2018
    Orlando, FL
    2002 BMW 525i
    I just changed the bulbs since they were the only thing I haven't changed yet and the problem remained on the same side. So safe to say it is not the bulbs.
    BEFORE CHANGING BULBS
    AFTER CHANGING BULBS
    <strong>
    Dec 2004
    CT, USA
    e28, e34, e39
    Can't you power them via a relay?
    demet
    Jan 2015
    Shreveport Louisiana
    recode the LKM pronto. PASOFT works well for doing this, and with your year model, you have the xenon option. were the lights halogen previously?
    Aug 2018
    Orlando, FL
    2002 BMW 525i
    Quote Originally Posted by mattmar1 View Post
    My car is a '02 but when i bought it it had aftermarket work done to the headlights. i believe they were xenon but they might have been halogen I'm not sure. Either way my car should be the facelift model. and i do not have bmw scanner for pa soft.
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    To do this right, you need to recode the LCM. Search and find out how to set up NCS or PA soft. Its not that hard, but like any computer crap, can be annoying to get set up.
    Feb 2001
    East Bay, CA
    M5, E61
    this is the best idea if all the others don't work.
    Jan 2015
    Quote Originally Posted by alexthebmwguy View Post
    run your VIN# and see how the car was originally equipped
    PASOFT (aka bmw scanner 1.4) with cable can be had on the big eauction site for around $30
    if its cable only, the software can be had thru mikes easy bmw tools
  1. E39 E39 OEM Hella xenon lights....
    By SilverBimmer540 in forum Exterior Lighting & Body Parts
    Last Post: 01-30-2009, 07:07 PM
  2. Parking Break Light Keeps Flickering
    By NooK89 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-22-2008, 03:00 PM
  3. FS:Almost new Hella Fog lights bmw e36 80 shipped
    By Blk4e36 in forum Exterior Lighting & Body Parts
    Last Post: 10-19-2007, 05:10 PM
  4. FS: brand new Hella xenon/HID ballasts
    By HardtopVette in forum BMW Parts For Sale
    Last Post: 09-13-2005, 11:28 PM
  5. FS:Hella xenon lights with angel eyes
    By bmw4life13 in forum BMW Parts For Sale
    Last Post: 07-16-2004, 01:02 AM
