Hello all,
I am looking for tips/guidance on replacing the accursed door lock grommet that goes from the door lock hook rod to the lock actuator. How in the hell am I supposed to press and re-hook the lock into the actuator? It seems nearly impossible, there is no room! I replaced the two white grommets on the lock assembly, one white grommet on the door panel. But the black one from the lock arm to the actuator, I need magic for it! How has anybody accomplished this?
Maybe not the best/fastest method, but I took the 2 white window sliders out of the window rail, so I could move the window up or down as needed, and I took the complete lock out. If you find a faster, easier method, let us know.
I also took this one out and de-dreased it and re-greased it http://bmwe32.masscom.net/sean750/do...kMechanism.htm
did not drill the rivets open, just cleaned it with brake cleaner
I may have to pay somebody to install this stupid grommet in, I don't foresee any possible way to install it. My plan is to try and snake the grommet up with the rod hook and try to press it in with a flat heat screw driver into the hole using the access hole that hides the door handle gasket lever.
There is an oval shaped plastic plug in the door jam edge of the door which pries out with a knife blade. I had to do this once. Have the door panel off and finess the grommet in place with a long slender screwdriver. Have to work from both the inside of the door and thru the outside access hole at the same time. I put a dab of JB Weld on it after finally getting it in place.
"The US Olympics bobsled team has renamed their sled 'Biden' because nothing has taken America downhill faster"
TheStigg (aka "gale")
92 735i 5-spd, turbo pending
89 535i 5-spd (may she rest in pieces)
94 325ic 5-spd
87 325is
did you remove the outer door handle gasket and the lock ring around the door lock from outside?
UPDATE:
I got the ********* grommet seated. I was cursing every engineer who worked on designing this mechanism in the process. I got creative and devised the following procedure:
1. Remove the lock assembly, remove old black grommet, seat the new one onto the hook. Make sure you also replace the white grommets on the lock assembly
2. Install the lock back into the door, make sure you hook the arm into the lock actuator hole!
3. Slide the black grommet up as far as you can. I am lucky with some small hands/fingers, I was able to slide up the grommet all the way up to where it meets its seat.
4. This is the tricky part. The grommet is now curved as it is on the curved portion of the hook. I used a thin flathead screwdriver between the hook and the actuator seat to "pull" the hook and its grommet close up against the seat. I used the access hole in the door jamb that is protected by the weather plug.
5. Slide a fat flathead from the lower portion of the hook (where it meets the door lock), and work your way up to the grommet. You will feel some resistance. PUSH. HARD. It took me a couple tries, but it seated into place.
I hope this helps somebody. I did not have to remove the door handle or lock cylinder. You will utter many curse words in the process, so make sure you're not offending anybody in the process.
