Results 1 to 9 of 9
Thread: Ground Cable/Strap Locations
    Sep 2018
    leesburg, FL
    1998 BMW 328i sedan
    I don't know where any of the ground strap locations are on a 1998 328i sedan. I recently purchased a chase bay$ ground wire kit.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    There are plenty inside the car. Which one do you want to know? go thru the ETK, for example it starts with battery http://bmwfans.info/parts-catalog/E3...trical_system/
    Engine is also grounded to the chassis.
    Then from page 0670.4-00 in the ETM, it shows all ground distributions https://www.scribd.com/doc/247124381...Wiring-Diagram
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Another good source (this address is for my 98 M, but you can find your car) : http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    One from passenger side motor mount to frame rail. Passenger rear corner of hood to engine compartment. Various locations in engine compartment such as by fuse box, by battery connection on other side. Multiple locations inside car. Battery to chassis in trunk.
    Jun 2010
    NY
    1997 328i
    I tried one time to remove the ground from the battery, at the chasis. I have no idea what they did to attach that nut, I used a breaker bar and I wasn't going to stress it because it probably would have snapped. I'm not sure what kind of nut they used (probably a pinch nut) but it did not want to move. Maybe they painted over it, not sure.
    Sep 2018
    leesburg, FL
    1998 BMW 328i sedan
    a brake light is out, came back on when a local mechanic tightened a ground cable, did not list which, but out again few weeks after; also affected interior lights
    Jan 2005
    Japan
    did you already check the fuses and the light bulbs?
    Sep 2018
    leesburg, FL
    1998 BMW 328i sedan
    Quote Originally Posted by shogun View Post
    fuses, bulbs, sockets have been replaced. After mechanic tightened a ground cable brake and interior light came on, out again after week or two
    Jan 2005
    Japan
    Why not ask the mechanic where he tightened a ground cable. If you paid for it and after 2 weeks it does not work again, I would talk with him.
  1. 1992 318i Engine bay ground strap location?
    By DotBeta in forum 1991 - 1999 (E36)
    Last Post: 02-10-2016, 02:56 PM
  2. Ground strap locations?
    By sifu424 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-23-2013, 04:44 PM
  3. Trunk Mounted Battery: Number and Location of Ground Cables
    By gsumzzz in forum 1975 - 1983 (E21)
    Last Post: 07-05-2012, 05:01 PM
  4. OBD 1 Valve cover Grounding strap location?
    By E30Alpina in forum 1992 - 1999 M3 (E36)
    Last Post: 08-14-2008, 08:23 PM
  5. Where is the grounding strap located in the engine bay?
    By x2nervisx in forum 1992 - 1999 M3 (E36)
    Last Post: 03-11-2008, 11:57 AM
