Results 1 to 17 of 17
Thread: Vemo 88c thermostat
    Jun 2019
    UK
    E38 740i Sport in Titan
    Vemo 88c thermostat
    Hi all - I always wondered why our engine’s run so hot at 105c and upwards, what do you think about the thermostat mod that lowers it the water temp to 88c? Ecs do it for 113 dollars plus shipping to old Blighty, so it ain’t cheap, but would do it if recommended by this learned forum?
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    It should be easy for you to get on your side of the pond, It's from a diesel I think 730d? get the behr one, I'm super happy with mine!
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
    Altamont, TN
    2001 540i/6, 2000 740i
    I did this mod on my 540/6. Also ran Evans NPG and my coolant system was unpressurized. Max temp I ever got was 98c in the middle of summer with the AC running. My indie mechanic even stressed tested the system and said it would hold the temps I mentioned. He was curious because he had never seen the mod before.
    Ran this system for 2 years until I sold the car a couple of months back.
    Sent from my ONEPLUS A6013 using Tapatalk
    Missouri
    '02 540i/6
    Where are folks getting the Behr unit?
    2002 BMW Titanium Silver 540i/6-speed Sport - ZHP Shift Knob - M5 Clutch/TTV Racing 15.6lb Flywheel - M60 Intake Manifold - N62 84mm TB - Dinan Intake Tube - 4" MAF Tube - DUDMD Tune - Magnaflow Resonator - Eibach 18mm Rear Sway Bar - Powerflex Front Sway Bar Bushings - CDV Delete - UUC SS Brake Lines - Koni Yellow Shocks/Struts - Eibach Springs - Zionsville Radiator & FDM
    Altamont, TN
    Quote Originally Posted by Iamthebull View Post
    Mine was Vemo.
    I got it from the Amazon UK site
    Jun 2019
    UK
    Thanks all - justbought it from Amazon VEMO Thermostat, coolant V20-99-1268
    Not cheap! But as I’m draining the coolant soon, I’ll do it then.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    It's always a good idea to get rid of the original TM thermostat!
    My BMW Repair YouTube Channel
    IL
    2000 740i sport
    I have been running this 88c tstat with custom programmed DME so it does not throw a 140 MAP tstat error...
    Jan 2017
    North Carolina coast
    2001 740iL Prod 4/2000
    Vemo 88c for the last 30k, absolutely no issues. 93c - 96c highway and hot traffic w/ac on.
    No reason not to switch it out, save the beast from baking in her own juices.
    IL
    2000 740i sport
    Although the coolant temps are lower i think the radiator produces more heat under the hood with the 88c tstat...
    May 2013
    Rochester, NY
    2001 740i Sport
    Underhood temps should drop some. Lower temp and pressure will be a bit nicer to the plastic cooling system parts, but with the tradeoff of burning a little more fuel and more risk of condensation, etc. building up in the oil in cold weather (if you don't take enough longer drives).
    IL
    2000 740i sport
    Quote Originally Posted by rslifkin View Post
    I believe the radiator is now working harder to keep the coolant temps down thus producing more heat which engages the fan clutch more often...
    Feb 2019
    Nebraska
    '01 E38 '99 DINAN 5
    Anyone running an 88 thermostat and an E65 clutch fan? Feedback?
    Jun 2019
    UK
    Am highly tempted to run the Evans waterless coolant, particularly as our cars run quite hot, but if I did I presume the 88 degree thermostat would be redundant?
    Feb 2019
    Nebraska
    '01 E38 '99 DINAN 5
    For those of you running the 88 degree t-stat....does it throw a check engine light?
    CURRENT:
    2001 740IL ALPINE WHITE
    1999 BMW DINAN 5 BIARRITZ BLUE
    PAST:
    2001 740I M-SPORT SCHWARTZ
    2001 BMW 330XI SPORT BLACK SAPPHIRE
    2002 BMW 325XIT TITANIUM SILVER
    2002 BMW 530I TITANIUM GREY
    2002 BMW X5 TOPAZ BLUE
    2003 BMW 325XI ELECTRIC RED
    1998 740IL ASPEN SILVER
    1998 740IL ORIENT BLUE
    1995 BMW 530I OXFORD GREEN
    1988 528E BLUE
    1980 320I WHITE
    1978 320I GREY
    IL
    2000 740i sport
    Mine does not! It will store an error in the DME but no check engine on the M62TU. It may if you run it on a non TU M62. I have had my DME programmed to remove the DME error for the map sensor so I dont even get a stored DME error for the missing MAP cooling sensor...
    Feb 2019
    Nebraska
    '01 E38 '99 DINAN 5
    Nice! Thanks! I've got two Behr 88s and will be installing them into both my 01s
    CURRENT:
    PAST:
    1988 528E BLUE
    1980 320I WHITE
    1978 320I GREY
  1. 88°C thermostat thoughts
    By jicaino in forum 1996 - 2003 (E39)
    Last Post: 07-12-2020, 01:30 PM
  2. Nother 62tu 88C thermostat data point
    By paul p in forum 1996 - 2003 (E39)
    Last Post: 07-21-2019, 02:03 PM
  3. Ecs 88c thermostat
    By jbhoopsbmw in forum 1996 - 2003 (E39)
    Last Post: 10-20-2016, 04:47 PM
  4. Replies: 12
    Last Post: 10-11-2016, 11:24 PM
  5. 88C thermostat instead of 80...big problem?
    By huhnchen in forum 1983 - 1991 (E30)
    Last Post: 06-02-2008, 11:41 AM
