$750 plus shipping or pick up in Las Vegas, Nevada. This is $1750 new!!!
Tilton OT-II BMW Clutch / Flywheel Assembly
Used but in good working shape, directly off a vehicle that had no issues.
(Tilton sells replacement parts cheap also to refresh while apart.)
Everything included to bolt on and go!
Fits all E36 including M3, and all E46 Non-M.
All hardware and throw out bearing included!
12.6 Total pounds for entire setup! Lightest on market!
$1750 brand new, buy here and save a ton.
Link to Tilton- https://tiltonracing.com/product/bmw...el-assemblies/
"Intended for BMW E46, E36, Z4 and Z3 models, Tilton’s BMW clutch-flywheel assemblies provide a substantial weight-loss advantage over the stock 36.6-lb assemblies. At just 13.6 lbs, Tilton’s 1-plate BMW clutch-flywheel assembly is the lightest option, cutting over 54% of the weight from the stock assembly.
A 2-plate option is also available, which provides greater torque capacity and an improved wear rate and, at 16.2 lbs, still comes in over 20 lbs lighter than the stock assembly. The 2-plate is also optionally compatible with E46 M3 models.
Tilton’s BMW clutch-flywheel assemblies include:
7.25″ cerametallic clutch
cerametallic disc pack
BMW flywheel
mechanical release bearing
bolt kit"
Still available?
