Results 1 to 7 of 7
Thread: clues to a failing radiator, or...?
    Feb 2004
    chicago
    '02 530i manual sedan
    hello. at 175k, i have been losing water out of the reservoir, leading to the error message on the MFD within a week of replenishing it, but the dash temp gauge never goes higher than where it should be. no apparent leaks anyway on the driveway. i know it's time to change out the radiator, but what else should be changed (besides the hoses)? i replaced the water pump/therm last year.
    thanks for the advice!!!
    berbes
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Replace all the hoses, the radiator, and the expansion tank (reservoir).
    Jun 2013
    Boston, MA
    99 528i/5, 05 ZHP conv
    This is certainly true, particularly if those parts are original. Don't forget the two hard plastic pipes under the intake manifold. They tend to deteriorate and crumble and/or leak over time.
    Its a bigger job to remove the intake but necessary if you want to keep it for a while
    I would also suggest you find where the leak is..Ask a mechanic to pressurize the cooling system and see if he can find the leak.
    Feb 2004
    chicago
    BEST forum out there...THANKS!
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by heather View Post
    You bet it is. (not that I may be biased)
    Thanks for the thumbs up Heather.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Heather
    This is an image of the cooling system hoses that have been mentioned.
    No.
    Part # / Description
    Price
    Upper Hose11-53-1-705-223
    525I,528I & 530I 1999-03
    $86.85
    $59.15
    ADD TO CART
    2
    Lower Hose11-53-1-705-224
    $86.85
    $59.15
    ADD TO CART
    3
    Water Pipe11-53-7-502-525
    Water Hose Assembly
    525I,528I & 530I 1999-03, ENGINE INLET
    $90.40
    $65.21
    ADD TO CART
    4
    Water Hose Assembly11-53-1-438-634
    525I,528I & 530I 1999-03, TO PUMP
    $78.40
    $53.40
    ADD TO CART
    5
    Water Hose Assembly11-53-1-438-633
    525I,528I & 530I 1999-03, PUMP TO RESERVOIR
    $78.40
    $53.40
    ADD TO CART
    6
    Water Hose Assembly11-53-1-438-632
    525I,528I & 530I 1999-03, RESERVOIR TO ENGINE
    $86.85
    $59.15
    ADD TO CART
    7
    Water Hose Assembly11-53-1-705-210
    Inlet Pipe
    $37.98
    $32.07
    ADD TO CART
    Also check the Temp sensor in your lower hose as the seal goes bad and causes a S L O W leak under pressure. Seal is only $.57
    O Ring Aux Fan Switch Aftermarket part - CSS091159010 $.59 to $.79 depending on vendor. Rockauto.comÜRO PARTS13621433077S.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Forum Fixer
    CDN 98 540iA M62 3.15
    If you are unsure of age of rest of cooling system, time for a full overhaul at your mileage. One tip that may help is to look for manufacturer's date stamps on the parts you think are replacing. Typically a month of manufacture clearly printed on the part(s) label; other times there is a circular dial etched in the plastic with 1-12 printed on it with an arrow with a year in the middle indicating month/yr or manufacture. If older than 5 years, replace it.
  1. Failing Radiator?
    By svginferno in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-16-2010, 05:30 PM
  2. 2nd Failed Radiator - Any other problems out there?
    By buyersagent420 in forum 1991 - 1999 (E36)
    Last Post: 11-22-2009, 04:19 AM
  3. e46 Pusher fan failed - radiator damaged?
    By MellowYellow M3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-08-2009, 03:20 AM
  4. oh knoez! Add me to the list of failing radiators
    By BMW Loe in forum 1996 - 2003 (E39)
    Last Post: 05-13-2007, 11:53 AM
  5. Word from BMW NA in regards to the failing radiator.
    By johngoga in forum 1995 - 2001 (E38)
    Last Post: 03-24-2004, 10:24 PM
