Results 1 to 6 of 6
Thread: M235xi Front Suspension Issues
    Jun 2019
    Greater Seattle
    2015 M235i, 2018 M3
    Quote Originally Posted by ltw97m3 View Post
    put a jack under the ball joint and raise the suspension up enough to create a load that will prevent the ball joint from spinning.
    I just tried that and the technique certainly works! Thanks!
    But, there is another one where the ball is on the top and the nut is at the bottom. How should I handle that one?
    Aug 2013
    1999 BMW M3 Coupe
    Which joint is that? All the ball joints I know about on the front end have the studs/nuts on the top above the joint. There's the two joints in each front control arm, plus the tie rod ends.
    Jun 2019
    Greater Seattle
    2015 M235i, 2018 M3
    Quote Originally Posted by TostitoBandito View Post
    Not sure what it's called but the pic is looking from bottom up and the one in the center has ball on the top.
    This is an F22 M235xi.
    All the control arms are mounted onto the Swivel Bearing, including the Strut on the top.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by DrivingPassion View Post
    This is the e36 forum … they don't have those arms
    But you can use giant channel locks to squeeze the ball joint and arm together and they tighten … usually works.
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    FL
    are slow.
    Stop what you're doing.
    This is the E36 forum, we use steel arms and a much different suspension layout.
    You do NOT have tapered ball joints.
    You also used the wrong style jack as well on the balljoint, and put it in the wrong location. It should be on the outer shell, not in the soft cover in the center. And it looks like you used a bottle jack, not a floor jack. You should have used a piece of wood or something to spread the force. You likely dented the shield of the balljoint there.
    If you look at the end of the balljoint, there is a torx bit that should fit inside of it. Just checked my garage, and it's a torx-40 bit, and a 21mm wrench. You can't use a socket wrench here, you have to have a regular wrench, or a ratcheting wrench. Lots of places sell them, homedepot near me has 21mm ratcheting wrenches for $14. Use the torx-40 bit to hold the balljoint still, and use the 21mm wrench to tighten it down. You should ALWAYS use high strength loctite on these bolts. BMW also recommends you change these nuts out, but many don't.
    I can't stress how vital it is that procedures in this area are followed perfectly.
    Read this:
    https://www.e90post.com/forums/showthread.php?t=788761
    You will need to pre-load the suspension before you tighten the bushings as well. You're okay to tighten the balljoints now, but the bushing end (if you removed these bolts) should not be tightened. You should raise the car on that side to the normal ride height (measure center of wheel to fender, mine is 13.7" for a sport package). You can do this tons of ways. The parts you're working with have specific yeild specs because of being aluminum and NOT steel. Make sure to use a torque wrench.
    -Dr. Seuss
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved from the E36 M3 sub-forum to the appropriate sub.
    88M3 AW 43k miles Project FS
  1. front suspension issues...
    By ty20404 in forum 1991 - 1999 (E36)
    Last Post: 04-26-2008, 10:01 PM
  2. DC Area Shop for front suspension issue
    By DesioMedia in forum Middle Atlantic - US
    Last Post: 08-20-2007, 02:19 PM
  3. Front Suspension Issue?
    By Magilla in forum 1983 - 1991 (E30)
    Last Post: 05-10-2007, 05:04 PM
  4. Front suspension issues
    By Strahan in forum 1995 - 2001 (E38)
    Last Post: 09-09-2006, 05:42 PM
  5. Front suspension issue
    By culkj013 in forum 1991 - 1999 (E36)
    Last Post: 07-31-2006, 04:38 PM
