Results 1 to 8 of 8
Thread: Radiator and AC
    Mar 2017
    Lithuania
    1998 BMW 523i Sedan
    Radiator and AC
    Hey guys I have a 98 bmw e39 with manual trans 523i. I am about to change the radiator since there is a lot of dye from ac system, the guy that recharged has put some in since I was loosing r134. Do I need to recharge the system after changing the radiator? If not, my system is newly charged at the moment, can I minimize the loss of refridgerant by not using it or does it not matter?
    San Jose, CA
    1997 BMW 540i 6 speed
    There's no need to disturb the A/C to replace the rad.
    You should be able to flush the cooling system with water to get rid of the dye, although the dye should not interfere with cooling.
    May 2018
    Austin, TX
    00 M5 | 03 540i | 94 NSX
    Are you talking about the AC condenser or the radiator?
    If you're talking about the condenser then yes you'll need to have the system recharged, you can't remove the condenser and keep your AC charge. It doesn't matter if you keep using the AC or not as the entire system will need to be evacuated before you start working on it. In the US it is illegal to intentionally release refrigerants into the atmosphere.
    San Jose, CA
    BTW, radiator = cooling device for the engine.
    Condenser = cooling device for the A/C, placed in front of the radiator.
    Evaporator = device inside the dashboard that absorbs heat from the air, which is dissipated by the condenser..
    Mar 2017
    Lithuania
    1998 BMW 523i Sedan
    Where is the condenser located? I know usually cars have 2 radiators(second one being the condenser), but I can't see the second one on e39
    Apr 2018
    Socal
    00 528i, 01 540i
    Condenser is the one right after the aux fan. Or like edjack said in front of the radiator.
    Mar 2017
    Lithuania
    1998 BMW 523i Sedan
    Found it on google images, but cannot find it on realoem to figure out the part number
    Mar 2017
    Lithuania
    1998 BMW 523i Sedan
    Found it. It's 64538378438
  1. Help: web asap: radiator and Ac condenser. In so cal
    By vegasoutlaw in forum BMW Parts Wanted
    Last Post: 05-31-2017, 10:48 PM
  2. Bmw e60 5 series front clip radiator condenser ac fan a/c shroud
    By bimmrboy88 in forum Engines, Performance Parts & Software
    Last Post: 04-17-2012, 10:28 PM
  3. euro radiator cover & ACS pic
    By cast in forum BMW Rides & Events
    Last Post: 07-24-2011, 12:11 AM
  4. e36 m3 ac fan and radiator
    By fred spencer in forum BMW Parts For Sale
    Last Post: 03-15-2006, 08:12 AM
  5. FS : AC Compressor , AC Fan & Radiator.
    By E30 FREAK14 in forum 1983 - 1991 (E30)
    Last Post: 01-03-2006, 08:46 PM
