Results 1 to 4 of 4
Thread: E36 Euro light adjustment
    Jan 2019
    Lafayette, CA
    1999 BMW M3 Dinan SC
    I just installed a set of Bosch Euro lights in my ‘99 M3. Lighting pattern seems off. Is there an adjustment to toggle the lights from RHD to LHD? Could something else be causing the “peak” on the driver side?
    Jun 2002
    Crystal Lake, IL
    '10 E90 M3
    Yes. You need to pull the headlight off, remove the low beam cover, loosen the 3 screws holding the projector bowl, and rotate to the other setting. I don't remember off the top of my head how they are labeled, but it will be obvious once you get the low beam cover off. I just did this on my car after installing some Bosch units, and realizing they were set to RHD... Luckily it's easy to get the headlights on and off on these cars.
    Current Whips: 10 E90 ///M3 - 04 GMC Sierra CCSB - 19 VW Atlas
    Past BMW's:
    85 325 - 87 325is M-Tech 1 - 91 318is S50 swapped - 91 318i 'vert
    97 M3/2 - 98 M3/4/5 (Alpine/Modena) - 98 M3/2 - 98 M3/4 (Dakar)
    06 330xi - 09 335i
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    On the E30, E34, E32 one can do it from the back of the headlights from engine bay, E36 you have to remove the headlights, rest of the procedure is same like shown here in the user manual form E32 https://750il.bmw7.hu/owners_manual/page_088.html
    Jan 2005
    Japan
    Just a note, cheapo aftermarket headlights are usually fixed, so either RHD or LHD, I just checked for a friend with an E36 some headlights for Japan, where we have RHD like in the U.K., so I checked in the U.K. auctions and found one offer which clearly stated
    E36 Year: 04/1991-03/1999, Note: Excl. Compact - , Front Headlight Left & Right, price on ebay u.k. about $200 incl. shipping
    Note: UK Right Hand Drive Beam Pattern, Excl. Electric Leveling Motor
    Bulb Fitment: H1 H1 W5W , Brand New, Boxed, Fully E-Marked & Road Legal, Manufacturer: Aftermarket, Warranty: 12 Months
    I have on my M3 in Japan these installed: Bosch H1 63128363084 right, 63128363084 left , realoem says only for RHD.
    Bosch are pretty expensive, one side only costs more than a pair of aftermarket ones, but the housing parts of the Bosch are more solid I know from comparing, for example the clip which holds the turn signal is much stronger on the Bosch than on aftermarket
  1. E36 Euro lights FS (ZKW and Bosch)
    By seventhstoned in forum Exterior Lighting & Body Parts
    Last Post: 12-14-2009, 09:06 AM
  2. orion v2 on e36 euro lights??
    By Bloodredsmurf in forum Lighting sponsored by BAVToys
    Last Post: 02-12-2009, 03:25 AM
  3. OEM E36 Euro Light Set
    By uconnr in forum Exterior Lighting & Body Parts
    Last Post: 08-05-2007, 10:00 PM
  4. WTB ZKW E36 Euro light parts
    By 99mtres in forum BMW Parts Wanted
    Last Post: 11-17-2005, 02:52 AM
  5. ultrasonic Hella Leveler system for E36 Euro Lights
    By umnitza in forum BMW Parts For Sale
    Last Post: 01-22-2005, 06:25 PM
