Results 1 to 18 of 18
Thread: DSC/ABS Pump... Need some advice...
    Sgf, Mo
    135i, 1SMC, S54 Roadster
    Hi everyone!
    Need some advice... My dad and I have a 2001 M Roadster with 19.5k miles. A couple of weeks ago I took it out what was really the first drive of the year thanks to a incredibly wet spring... A couple of miles in the ASC and ABS lights came on. I initially figured it was a bad sensor or something as is often the case. Nonetheless I made an appointment with my dealership--whom I have a VERY good relationship with.
    Anyway... My dad dropped it off yesterday. Not good news. Seems the DSC (ABS?) Hydraulic pump failed and leaked hydraulic fluid on the unit and fried it--at least according to my dad who talked to the service manager. Part number is 34512229827
    The dealership quoted us $3,800 for the PART. So we are looking at north of $4k for the job--even with the discount we normally get. I typically don't get used parts as I always feel if the one in my car failed why wouldn't a used replacement? But $3,800 is nutso.
    Anyone have any ideas? Is used the way to go? Also, it looks like it is interchangeable with the E46 M3; hopefully that is the case.
    Thanks!
    Jul 2004
    Houston, TX
    36 Cylinders
    For your model, it is interchangeable with E46 M3. So you could get a used one, and then code it (programming) to your car. It has to be programmed, but that isn't hard.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Sgf, Mo
    Is this something our dealership (or an indy shop) could do? Or would we have to go about it some other way?
    Jul 2004
    Houston, TX
    36 Cylinders
    Dealership may or may not program used parts. But a knowledgeable indy can, or even do it yourself if you're good with computers. The tools needed are all here in the Z3 subforum.
    -Abel
    Sep 2014
    The Netherlands
    E46 BMW 330/ Een BMW Z4
    Quote Originally Posted by BMW135 View Post
    Hi everyone!
    Thanks!
    In Europe it's very cheap they sell for less than $1,000.
    I am sure including shipping will be way cheaper.
    Let me know if you like to get one.
    You can send me a message.
    Sent from my MI MAX 3 using Tapatalk
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    The units are sealed I’m surprised it could be fried by a “leak”. They get wet all the time when driving and don’t fry. Able does he have the module that cracks the solder pads causing the false abs pump fail code. If so then it’s about a 175$ fix by module master.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by z3forlife View Post
    ... does he have the module that cracks the solder pads causing the false abs pump fail code. If so then it’s about a 175$ fix by module master.
    Here's DIY on sending the pump to Module Master for a $198 repair:
    https://forums.bimmerforums.com/foru...=diy+asc%2Fabs
    BMW MOA 696, BMW CCA 1405
    Jul 2004
    Houston, TX
    36 Cylinders
    These pumps are different than the "usual" Z3 pumps, it's not an ASC. Module Masters may have a fix, you'd have to check.
    There are plenty in eBay for $175-299, or visit your local junk yard.
    It MUST be from the early E46 M3 or Z3M with S54.
    Nope, DSC3-ES as in the M3 and Z3M (S54) is not repairable. https://modulemaster.com/rebuilds/sh...s/ate-m20-bmw/
    -Abel
    Sgf, Mo
    That's what he told my dad... I can't imagine he would be trying to screw us as we know the Service manager really well...
    At this point I think we are going to roll the dice and get a used unit. As little as the car gets driven I can't imagine it would be a problem again.
    Can anyone recommend a BMW recycler?
    Oct 2012
    Louisville, KY
    ... Can anyone recommend a BMW recycler?
    Here's one, but this is apparently not the right pump for an M.
    https://primebmwparts.com/collection...hydro-unit-oem
    This place has a few different ones.
    http://www.brickyardimportedcars.com/
    Here's one for "Assembly, 3.0L, w/o dynamic stability control ", i.e. non-ASC?
    Sgf, Mo
    Quote Originally Posted by Vintage42 View Post
    I think that's a different part number. My understanding is it has to come from an s54 car?
    Jul 2004
    Houston, TX
    36 Cylinders
    Car-part.com searches all junk yards.
    Ebay is good too. You'll have a great selection if you search for BMW e46 M3 abs pump.
    Choose one that is from a more reputable seller.
    -Abel
    Oct 2012
    Louisville, KY
    Is the one from brickyard also not right?
    Jul 2004
    Houston, TX
    36 Cylinders
    Not right. It has to be from an S54 M3 or Z3M with S54.
    -Abel
    Sgf, Mo
    Thanks! I'll start looking. Wish I had the time to just put it in myself...
    Aug 2012
    Kansas
    It only takes about 5-10 minutes to pull out the module. Disconnect harness and a few torx (I believe) screws and it’s out. Good luck. I don’t know if that will save you anything since your having the dealer/Indy code it
    Jul 2010
    Ozark bumps
    00 M Roadster 17 Cayman
    Bavarian auto parts is a good source (I got a module from them them last year). Pretty quick ship and 1 yr warranty.
    I note your location. Import Specialists on E Pythian can install or Alternative Beemer Service in Rogers (AR) is another alternative to dealer (I doubt dealer will install used part). Both have done work for me in past.
    (and I will add the local dealer is not what it was in years past-too many changes in last few years)
    Washington, D.C.
    S54 e36/8
    There are two options:
    1. Use the company on ebay (I'd have to look it up) where you send your unit in for diagnosis and repair and it's about $80-$100 if they can fix it. When I used this service, they called and said it was not fixable and i could buy a reman one for like $200 or $400.
    2. buy a used one. I was lucky and there is a guy who parts out m5's local to me and I got a unit for $85 shipped. I used my laptop with INPA and whatever the app is that you need to align the ABS unit with your car to do the replacement myself.
    I would not pay anyone to do this job or pay north of $200 all in to fix it yourself.
    EDIT: https://www.ebay.com/usr/bba-remanin...72.m2749.l2754
  1. E39 DSC / ABS Confusion Need clarification
    By PhotoDoug in forum 1996 - 2003 (E39)
    Last Post: 08-13-2017, 01:21 PM
  2. 2008 BMW 335i E92 DSC/ABS issue, need help
    By greg328 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 12-23-2015, 02:18 PM
  3. Replies: 22
    Last Post: 07-12-2014, 05:23 PM
  4. Middle of replacing water pump, need some advice.
    By gorillajin in forum 1996 - 2003 (E39)
    Last Post: 07-30-2012, 10:49 PM
  5. replaced ABS pump - need to reprogram computer?
    By bird67 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-28-2007, 10:23 AM
