Results 1 to 13 of 13
Thread: 1998 540 Power steering pump growls when I turn the wheel but mostly when warm
    May 2018
    Rockford
    If I drive it more than 30 mins the thing growls, but when I first start driving, it's fine. Are the pumps rebuildable?
    Jan 2016
    Ca
    2001 525it
    How is the fluid level??? No you just order a new one
    Jaaap is offline ☀ ☁ ☂ ☃ ☏ ☠ ☢ ☣ ♕ ♫ ✂
    Jun 2008
    Belgium
    Alpina B10 e39 / F3
    I had this on my e38 once and a new reservoir (which has a filter) fixed it.
    May 2018
    Rockford
    After I took it out of storage in April, it growled, but fluid was a bit low, added and fine, now noticing it more, fluid level is fine. I even replaced some old with some new, but maybe a cup or 2. So no leaks and fluid level good.
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    What kind of fluid are you using?
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
    May 2018
    Rockford
    Dex 3 I think.
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    Do NOT mix fluid types in the power steering pump.
    Flush it all, and replace it with the approved fluid type. I think "Pentosin Synthetic ATF-1" is the right fluid for your car. Check it first.
    May 2018
    Rockford
    Didn’t mix fluids, forget where I read the type it needs.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Look on the cap, it will say what to use.
    May 2018
    Rockford
    Actually all it says is use ATF only.
    Jan 2015
    Shreveport Louisiana
    though on some of the later replacement caps, and on some of the replacement reservoirs with caps, they are marked for use with chf-115 fluid, which didnt come in to play til the e60 model came out. dont use chf-115 in the e39.
    San Jose, CA
    1997 BMW 540i 6 speed
    OP, when did you last replace the ATF?
    May 2018
    Rockford
    Update-the steering linkage joints apparently are old and dried out. Got a needle grease gun attachment and shot grease into them. No more noise.
  1. Replacing e39 540 power steering pump - opinions?
    By Cora540 in forum 1996 - 2003 (E39)
    Last Post: 05-26-2015, 06:12 AM
  2. WTB: Power Steering Pump for 540
    By Rallim in forum 1996 - 2003 (E39)
    Last Post: 12-08-2011, 08:08 PM
  3. E36 E36 M3 1998 Power Steering Pump 107k miles
    By e30hijinks in forum Drivetrain & Transmission Parts
    Last Post: 09-18-2010, 01:34 PM
  4. Inconsistent steering on 540 - bad power steering pump?
    By resinears in forum 1996 - 2003 (E39)
    Last Post: 06-08-2007, 10:12 PM
  5. FS: 1998 328i Steering Rack, Power Steering Pump
    By DeanB in forum BMW Parts For Sale
    Last Post: 02-22-2004, 09:42 PM
