RM European Auto Parts
Results 1 to 4 of 4
Thread: P1623 crank no start all cyl missfire
    Jun 2019
    Indiana
    2000 z3 2.5 roadster
    P1622 crank no start all cyl missfire
    2000 z3 2.5 roadster...was running idling fine no cel's. Last short drive it did have a couple mild bucks at 40/50 mph..Sat for a couple days then crank no start. Code reader says 1622 and all the cyl missfire codes..this is after a clear. Threw the codes from cranking. Cam or crank sensor ? Does the thermostat issue keep the car from starting..ha.it has new intake boots i just installed plugs and new vc gaskets. I did get a new fuel pressure relay but have not installed it yet, as i havent confirmed if the location is under the steering column ? Also have replaced key and battery is good. Also when changing the vc gaskets i found a copper washer baked into the remains of the old cw gasket where the front coil pack ground wire connects to the engine..i didnt put it back as there wasnt one on the rear grounding point ? The car did run /idle fine (except for the above mentioned mild bucks) for a short 10-15 mile drive after that.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I’m betting it’s the crankshaft position sensor. What tool are you using to scan the engine computer? What are the codes?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    +1
    Also fuel pumps are known to just die as well, so do check for fuel pressure.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    +1.
  1. URI Crank pulley E36 6 cyl.
    By vwrado in forum BMW Parts For Sale
    Last Post: 06-19-2006, 02:53 AM
  2. All of a sudden, long cranking before start...
    By 99E36M in forum 1992 - 1999 M3 (E36)
    Last Post: 05-26-2006, 12:48 PM
  3. S/C crank pulley for 4 cyls
    By nuvola rossa in forum Forced Induction
    Last Post: 03-13-2006, 07:10 PM
  4. E32 long cranking to start
    By jim.edwards in forum 1988 - 1994 (E32)
    Last Post: 09-03-2003, 10:11 AM
  5. CRANK, CRANK no start. HELP!
    By martin23 in forum 1983 - 1991 (E30)
    Last Post: 04-14-2003, 03:37 PM
