Results 1 to 2 of 2
Thread: Ideas to protect exposed O2 sensor plugs?
    MINIz guy's Avatar
    MINIz guy is offline #buttstuff2k14 BMW CCA Member
    Bear, DE
    rolls coal
    I found out to have my O2 sensors coded out, they also have to stay unplugged. Does anybody have a creative way to keep dirt and grime out of the connectors that are unplugged (primarily the ones from the car)? Don't want to cut the wires on perfectly good sensors, and can't remove the sensors for inspection.
    May 2017
    Owings, Md
    1998 328i
    To retain the sensors (at least appearance) for inspection, you could install a pair of old failed pair of sensors, clip the ends of each sensor's harness off and use heat shrink to make them appear intact. This would have the same effect as the sensors being unplugged. This advice is for off road use only of course
  1. M52 engine o2 sensor plug confusion
    By bostongrun328ic in forum 1991 - 1999 (E36)
    Last Post: 12-09-2008, 12:51 AM
  2. Dip Stick/O2 sensor plug
    By JohnnyScene in forum BMW Parts Wanted
    Last Post: 03-05-2008, 02:12 PM
  3. WTB: O2 SENSOR plug with 4 female pin connector plug!!
    By de45t in forum BMW Parts Wanted
    Last Post: 04-08-2007, 01:09 AM
  4. O2 sensor plug size.
    By phillyB///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-12-2005, 07:17 PM
  5. Anyone know this O2 Sensor Plug part #..?
    By Jesse325i in forum 1991 - 1999 (E36)
    Last Post: 06-17-2003, 02:11 PM
