Results 1 to 4 of 4
Thread: Is my thermostat going bad?
    Jul 2016
    Irmo SC
    1999 540i, 2000 540i
    99 540i 6speed.
    Few days ago I noticed my coolant temp hovering lower than usual, in the low 90C. My car topically operates around the 104 -107C range, a bit higher if in traffic. The highest I’ve seen it is at 110. So when I saw the lower temperature readings on the coolant I was pleasantly surprised. This only lasted for two or three days and now it is back to normal temperature range. I monitor coolant temp on the cluster menu, #7.
    Could this be a sign of my thermostat or temperature sensor going bad? I think maybe it was stuck open for a few days and that’s when it was showing the lower operating temperatures. My new cheap scanner says this.
    May 2013
    Chicago, Illinois
    2000 BMW 528iA
    My thermostat went bad a couple of years after I bought the car new. The temp gauge would only get to around 11 o'clock and the heat from the vents was lukewarm. At the time I didn't know how to use test 7 to check the coolant temps so I have no idea just how low the temps were.
    2000 528i sport
    EMP Stewart water pump
    Dice iPod adapter
    Alpine amplifiers
    MB Quart speakers
    MTX BGE12 subwoofer
    AudioControl EQL equalizer
    San Jose, CA
    1997 BMW 540i 6 speed
    Bad 'stat is my guess.
    CT
    E28, E32, E39, E53, E90
    Yeah the thermostat is probably bad. How long does it take for the car to reach operating temperature (temp needle in the middle of gauge) from a dead-cold start in the morning?
    If the warm-up time is unusually long like it was on our X5 in this video, its probably a stuck thermostat. Really common, even on our X5 where the t-stat was only a few years old.
    Not a V8 E39, but the concept is the same, hope it helps:
    link: https://youtu.be/JAR7UDSDUew
  1. How Do You Know If Your Thermostat Is Bad???
    By kooljess in forum 1995 - 2001 (E38)
    Last Post: 12-31-2016, 02:32 PM
  2. My new thermostat is bad?
    By 54zero in forum 1996 - 2003 (E39)
    Last Post: 10-08-2013, 06:58 PM
  3. If the thermostat went bad would that stop the car from starting?
    By E39CNY in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-10-2010, 07:46 PM
  4. how can you tell if a thermostat is bad?
    By ///Mracer in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-29-2009, 08:49 PM
  5. Thermostat gone bad? What else...?
    By 00Bolt in forum 1999 - 2006 (E46)
    Last Post: 03-13-2005, 11:10 PM
