Results 1 to 9 of 9
Thread: Z3 will not rev past 5200rpm, code p0500
    Jun 2019
    Connellsville pa
    2016 bmw x1
    Hi everyone, i have a problem with my 97 z3. It will not rev past 5200rpm and i have a vss code p0500, abs and atc are working as they should. I think i'm losing the vss signal from the asc to the dme. I,m hoping someone here knows what pin at each ecu that would be. Any help is appreciated
    Jul 2004
    Houston, TX
    36 Cylinders
    Scan the whole car with a BMW specific code reader on all modules. They will offer a good hint if there is loss of communication, or what else. P codes aren't terribly useful in this case.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jun 2019
    Connellsville pa
    2016 bmw x1
    I'm reading 0mph on live data so i'm pretty sure its a wire from the abs/asc to the dme
    Jun 2019
    Connellsville pa
    2016 bmw x1
    So this is what i found out so far, vehicle speed is learned by the right rear abs sensor. It sends speed info to the abs/asc computer, the signal is then sent to the dme from the asc. The first part of that must be good as i do not have any problems with my abs system and if i unplug the right rear abs sensor i get an abs light, so i must be losing the vss signal from the asc to the dme . I just don't know what pins that would be .
    Jul 2004
    Houston, TX
    36 Cylinders
    Does your speedometer work?
    -Abel
    Jun 2019
    Connellsville pa
    2016 bmw x1
    Yes, all other gauges and systems are working correctly
    Aug 2017
    What about the vehicle speed sensor in the differential? I don't know if a defective speed sensor there would trigger a CEL though.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    The differential speed sensor goes to the cluster and is for the speedometer, on board computer, cruise control, volume adjustment on the radio, speed-sensitive wipers, etc. The wheel speed sensors go to the ECU and are for ABS and traction control
    BMW MOA 696, BMW CCA 1405
    Jun 2019
    Connellsville pa
    2016 bmw x1
    Update , i found a wiring print. I ran a wire from pin 15 on dme to pin 15 on asc , just up over the windshild for now, test drove and the code went away. I'm able to read vehicle speed on my scanner and my red line is back, so other then running a wire the correct way the car is FIXED. Hopefully this can help someone . My thanks to everyone who replied .
  1. Will not rev past 3k
    By jb750il in forum 1988 - 1996 (E34)
    Last Post: 09-07-2015, 09:38 PM
  2. Replies: 12
    Last Post: 08-16-2013, 09:51 AM
  3. Not being able to rev past 3000 rpm when engine cold?
    By JDMMAN in forum 1992 - 1999 M3 (E36)
    Last Post: 09-10-2009, 01:21 PM
  4. Car Will Not Rev Past 2000RPM-Please Help
    By alpinem3/// in forum Forced Induction
    Last Post: 03-08-2008, 06:42 AM
  5. Z3 Coupe not available in Canada?
    By MPRESION in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-15-2001, 12:46 AM
