Results 1 to 13 of 13
Thread: Camber on H&R Lowering springs
    Houston, Tx
    '78 320i
    Hey all, made a post on the FB group just looking for input from folks outside of that platform.
    After installing my springs I thought the rear was pretty low but didn't realize it was low enough to have a 3 degree camber.
    What camber are y'all on? This is pretty noticeable. Almost stance type camber...
    All new rubber around the car. Poly uro subframe bushings, new rubber otherwise. Just thinking, if I super torqued down the subframe bush they would compress a bit so I'll check that.
    I'd like to fix the camber a bit. I fear the end would break loose too easily with this setup.
    Sent from my Moto G (5S) Plus using Tapatalk
    Aug 2001
    NC
    E30M3,318is,318i,E21320
    Easiest is check subframe bushings. You can install them to have the shortest part turned up and even bolting them under the subframe. Bring the subframe as close to the body as you can will decrease rear camber.
    Roll Center (RC) and camber go hand in hand. Lowering RC increases camber; either by shorter springs or lowering the subframe. You want to raise the RC height in the rear to decrease camber. Tires will wear fairly fast on the street at 3degrees static.
    Things are worse when the rear rolls which happens easier with lower RC unless a way to adjust it statically. Factory there isn't a way to do that so just raising the subframe should fix it. Should at least get in the 1.5-2.0 range.
    Reference from E30s but same applies
    https://www.bimmerforums.com/forum/s...0#post29590430
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
    Houston, Tx
    '78 320i
    Also regarding the alignment, I posted the before sheet if youre wondering why toe and all that looks way off.
    I wonder how much height on the subframe we are talking to correct?
    I installed the eurometric subframe bushings. I do know when I first torqued em down with my impact gun I squished them too much. I thought I backed it off a lot but I will have to check. but this cant be more than 1/4 of an inch of compression Id think. Youll see below the tab to mount them is dead even, so there's no wrong way to isntall them (I think)
    Aug 2001
    NC
    I'd hope those have a internal sleeve to tighten against so can't crush the bushing when torqued down. No sleeve is just lazy engineering. Yes just a 1/4" is enough to gain more camber. That mount being in the middle kinda messes up gaining some back. If the bushing is thinner on one end make that up against the car when installed. Also bolt the bracket under the subframe further making the top area shorter. Idea is get the subframe close as you can to the body to correct the camber some.
    It only takes 12mm or so on e30's to change close to a degree. Lots of factors like tire/wheel size etc but these days everybody is on 17s
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
    Houston, Tx
    '78 320i
    Yes it has a metal sleeve. Well I was thinking I needed to lower the subframe, add height to the bushings... but If I need it closer to the body I'll just torque her down more and see how she does.
    Aug 2001
    NC
    Quote Originally Posted by jaredmac11 View Post
    If has a sleeve I'd torque down to the sleeve should be a dead stop. For sure easiest thing to try.
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    I installed the eurometric subframe bushings. I do know when I first torqued em down with my impact gun I squished them too much. I thought I backed it off a lot but I will have to check. but this cant be more than 1/4 of an inch of compression Id think. Youll see below the tab to mount them is dead even, so there's no wrong way to install them (I think)
    Josh did a video on reusing the rubber mounts with the same shell,,drill holes in the rubber and sleeve the sides of the rubber mount to fill in the exposed gaps and drilled holes, then pour in polyurethane mixture strength of your choice-it finishes them off nicely . There are also on the market polyurethane inserts that reuse the older hardware.
    s-l500.png 80 Shore-Red and 90 Shore-Mello Yellow Color.
    Your Welcome.
    Randy
    Nov 2007
    Cool
    You can adjust camber by moving the inside trailing arm bushing up/down vertically while keeping the outside trailing arm bushing stationary and vice versa, toe-in can be changed by single Z-Axis adjustment in forward/backward direction same as camber-holding one stationary. BMW has eccentric trailing arm bushings that adjust camber, they are unique in that they have markings on them as adjustment points--I have not seen these in some time-probably still available in Germany somewhere by job order or old stock-pictures of them in the BMW Blue Book and details. Caster is another story as both sides of the trailing arm bushes have to be moved to adjust Caster in the z axis directions.
    So, Trailing arm adjustments, Vertical one side-Camber, Z-Axis one side-Toe in, Z-Axis double or 3rd dimension both sides- Caster, Front end is another thing all together. Horizontal adjustment--adjusts the wheel base--not done except by those whom want to do a lot of work and modifications.
    Randy
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    Ahah, I think I installed my bushings backward, this would explain my cartoonishly large camber angle! Thanks Jody
    -John
    Jun 2016
    Austin, TX
    1978 323i
    Jared-
    My car had a similar look after installing the eurometric subframe mounts, I reinstalled them with the ears under the subframe as Jody suggested, and it does appear to have corrected the visible camber issue.
    Houston, Tx
    '78 320i
    Oh shoot, thats good input. I had no idea such a small thing would make such a difference. Ill re-do the job this weekend and save my poor $40 tires.
    Im just not cut out for the stance life.
    Nov 2007
    Cool
    You have the degrees camber with the rear axle carrier mounts on top of the rear axle carrier(stock setup), interesting to see the degrees camber with the rear axle carrier mounts below the rear axle carrier.
    Randy
    Houston, Tx
    '78 320i
    Well the alignment was $130 so the world may never know... but I'll see if I can accurately record the camber to match what I have today and then record it afterwards.
  1. Billys/Konis/lowering springs with camber plates?
    By scooper in forum 1992 - 1999 M3 (E36)
    Last Post: 10-29-2010, 02:08 PM
  2. Lowering springs and camber?
    By Pyrodon in forum 1975 - 1983 (E21)
    Last Post: 05-15-2009, 05:11 AM
  3. installed lowering springs now negative camber
    By DrifterX27 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-11-2008, 09:56 PM
  4. Rennsport E36 lowering springs, camber
    By black328ride in forum 1991 - 1999 (E36)
    Last Post: 04-29-2008, 10:51 PM
  5. How do I fix my CAMBER? Lowering Springs question
    By Quailmann7 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-14-2007, 11:37 AM
