Results 1 to 4 of 4
Thread: NO start, no crank - is starter out?
    Mar 2014
    Crown Point, IN USA
    99 & 10 528i
    Stranded yesterday and had to tow. Battery is only a few weeks old. Car wont's start of crank, can hear fuel pump kick in. Votage is going to starter and starter signal wire. Must be dead starter right???
    Oct 2005
    ontatio
    1999 mustang gt
    If you checked the voltage at the starter signal wire right at the starter connector while it's plugged in, and the starter has good ground, that's 100% a bad starter.
    EDIT: As long as the engine or a pulley isn't seized.
    Jan 2016
    Ca
    2001 525it
    wack the starter with a hammer if it starts that's what it is what model,is this
    N52 starter failure is common, but yes, we need to know what year and model.
    Funny thing is I've never gotten the hammer trick to work on an N series engine starter. But I've had it work on a ton of M series engines. Starters must be failing in a different place.
  1. Replies: 25
    Last Post: 06-25-2015, 06:22 PM
  2. No-start, no-crank. Starter getting power & signal.
    By ThreeD in forum 1992 - 1999 M3 (E36)
    Last Post: 06-07-2015, 11:10 PM
  3. car won't start or crank? battery tested....
    By Roffle Waffle in forum 1991 - 1999 (E36)
    Last Post: 02-20-2005, 04:39 PM
  4. Help: Will not start after crank pulley install!
    By caldweb in forum 1992 - 1999 M3 (E36)
    Last Post: 07-15-2004, 08:28 PM
  5. NIB ultra start 2way Alarm & remote starter
    By RanGer498 in forum BMW Parts For Sale
    Last Post: 07-24-2003, 07:06 AM
