Pin |
Type |
Description /Signal type |
Connection /Measuring notes |
1 |
A |
Signal, oxygen sensor heater |
Connector, DMW oxygen sensor 1 |
2 |
A |
Idle actuator closing winding |
Idle actuator |
3 |
A |
Fuel injector cyl. 1 |
4 |
A |
Fuel injector cyl. 4 |
5 |
A |
Fuel injector cyl. 6 |
6 |
M |
Ground, fuel injector |
Ground point |
7 |
A |
Fuel injector cyl. 7 |
8 |
A |
Defect lamp (USA only) |
Instrument cluster |
9 |
E |
Start signal |
Start relay |
10 |
E |
Antitheft alarm system signal (EWS) |
Electronic immobilizer control unit (EWS) |
11 |
A |
A/C compressor signal |
Heating and A/C control module |
12 |
E |
Signal, terminal 50 |
Ignition switch |
13 |
E |
Knock sensor signal |
Knock sensor |
14 |
Not used |
15 |
Not used |
16 |
E |
Intake air temperature |
Intake air temperature sensor |
17 |
E |
Ground, hot-film air mass meter |
Hot-film air mass meter |
18 |
E |
Oxygen sensor signal |
Heated oxygen sensor 2 in front of catalytic converter |
19 |
E |
Heated oxygen sensor 1 in front of catalytic converter |
20 |
A |
Crankshaft sensor signal (speed and position) |
Crankshaft sensor |
21 |
A |
Camshaft sensor signal (cylinder reference) |
Hall-effect sensor, camshaft 1 |
22 |
A |
Ignition signal cyl. 6 |
Ignition coil cyl. 6 |
23 |
A |
Ignition signal cyl. 3 |
Ignition coil cyl. 3 |
24 |
A |
Ignition signal cyl. 7 |
Ignition coil cyl. 7 |
25 |
A |
Ignition signal cyl. 2 |
Ignition coil cyl. 2 |
26 |
E |
Terminal 30 |
Fuse F109 |
27 |
A |
DME relay |
DME relay |
28 |
M |
Ground for electronics and sensor shield |
Ground connector |
29 |
A |
Idle actuator opening winding |
Idle actuator |
30 |
E |
Heated oxygen sensor 1 in front of catalytic converter Heated oxygen sensor 2 in front of catalytic converter |
31 |
A |
Fuel injector cyl. 5 |
32 |
A |
Fuel injector cyl. 8 |
33 |
A |
Fuel injector cyl. 3 |
34 |
M |
Ground, remaining output stages (apart from ignition and fuel injectors) |
Ground point |
35 |
A |
Fuel injector cyl. 2 |
36 |
A |
Signal, A/C compressor relay |
37 |
Not used |
38 |
Not used |
39 |
Not used |
40 |
E |
Knock sensor |
41 |
E |
Knock sensor |
42 |
E |
Fuel reserve signal |
43 |
Not used |
44 |
E |
Throttle potentiometer signal |
Throttle potentiometer |
45 |
M |
Signal, hot-film air mass meter |
46 |
A |
Signal, oxygen sensor Ground |
Oxygen sensors |
47 |
Not used |
48 |
Not used |
49 |
A |
Ignition signal cyl. 1 |
Ignition coil cyl. 1 |
50 |
A |
Ignition signal cyl. 5 |
Ignition coil cyl. 5 |
51 |
A |
Ignition signal cyl. 4 |
Ignition coil cyl. 4 |
52 |
A |
Ignition signal cyl. 8 |
Ignition coil cyl. 8 |
53 |
A |
Throttle potentiometer + 5 V supply |
54 |
E |
Terminal 87 |
Fuse F1 |
55 |
M |
Ignition ground |
Ground point |
56 |
E |
Terminal 15 |
Ignition switch |
57 |
Not used |
58 |
Not used |
59 |
E |
Signal input Characteristic map, cooling |
60 |
E |
Programming voltage input |
Diagnostic connector |
61 |
E |
Signal input Tank ventilation valve |
Charcoal filter valve |
62 |
Not used |
63 |
E |
EKP relay |
Fuel pump relay 1 |
64 |
Not used |
65 |
Not used |
66 |
Not used |
67 |
Not used |
68 |
Not used |
69 |
E |
Air conditioning system standby signal |
70 |
E |
Knock sensor |
71 |
M |
Ground for temperature sensor, throttle potentiometer and knock sensors |
Ground connector |
72 |
Not used |
73 |
Not used |
74 |
E |
Signal, temperature sensor |
Dual temperature sensor |
75 |
Not used |
76 |
E |
Heated oxygen sensor 2 behind catalytic converter |
77 |
E |
Heated oxygen sensor 1 behind catalytic converter |
78 |
E |
Crankshaft sensor |
79 |
E |
Rear right speed signal |
ABS control unit ABS/ASC control unit |
80 |
A |
TD signal (engine speed) |
Connector TD signal |
81 |
Not used |
82 |
A |
Ignition timing adjustment |
Not used |
83 |
A |
Injection signal |
Integrated electronic control unit (IKE) |
84 |
Not used |
85 |
E/A |
CAN-bus low |
AGS transmission control unit |
86 |
E/A |
CAN-bus high |
87 |
Not used |
88 |
E/A |
Diagnostic link TXD |
