Results 1 to 7 of 7
Thread: Technical information of oil pump
    Mar 2017
    34406 Kagithane/istanbul
    7er E32 1990 750iLA L7
    geçici konu
    aşırı sıkılmış bir cıvata yok mu?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    The oil pump problem was mainly on the M60 engine. Not on your M70. Tightening torques for the bolts are here, section 11-26 http://www.e38.org/bmw_torq.pdf
    Mar 2017
    Jan 2005
    Japan
    The actual chain slack must be 10mm +/- 2mm and can be adjusted by turning a hex bolt
    Maybe you check your chain tensioner, the old one has been replaced against a new one https://www.bimmerforums.com/forum/s...hain+tensioner
    Mar 2017
    Daha gergin
    Jan 2005
    Japan
    Do it as specified in the workshop manual.
    The timing chain is comprised of a series of links in the chain – similar to those found on a bicycle chain. The links move on the toothed sprockets which are located on the ends of the crankshaft and camshaft and are responsible for opening and closing valves in the cylinder head and moving pistons and connecting rods in the combustion chamber. The timing chain can start to stretch and wear over time, which will cause the engine's timing to be inaccurate and produce a few warning signs.
    Worn Timing Chain Symptoms: Rough Idle. When a timing chain is worn, it develops slack and becomes loose. No Ignition. If a worn timing chain becomes so loose that it no longer sits correctly on the gears and doesn't turn properly when the crankshaft is engaged, the engine will not turn on. Poor Function .Rattling Noise
    A too-tight timing chain causes undue friction /binding and wear.
    Mar 2017
    Yes shogun, the issue of wear is very important.
    The chain tension of the oil pump should be a little soft and flexible, which apparently
  1. Oil pumps, flow rate, cavitation and restrictors. Technical
    By Bebbetufs in forum 1991 - 1999 (E36)
    Last Post: 01-12-2016, 07:22 PM
  2. Oil Pump Nut DIY Technical Article
    By craaaazzy in forum 1992 - 1999 M3 (E36)
    Last Post: 09-26-2006, 05:38 PM
  3. Oil Pump Nut DIY Technical Article
    By craaaazzy in forum 1991 - 1999 (E36)
    Last Post: 09-14-2006, 08:33 PM
  4. I Just Called Turner on the Oil pump NUT
    By J10B in forum 1992 - 1999 M3 (E36)
    Last Post: 06-25-2002, 02:03 PM
  5. Oil Pump problems
    By jake_97M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-24-2001, 12:03 AM
