Results 1 to 15 of 15
Thread: What is this noise??
    Feb 2019
    Nebraska
    '01 E38 '99 DINAN 5
    Feb 2019
    Nebraska
    '01 E38 '99 DINAN 5
    Anybody??
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Sounds like a start with some chain slap (tensioner go bad?) and then wind from the fan.
    While not desirable, not necessarily alarming to me ...
    2001 750iL DD74441
    E65 fan & clutch, E65 headrests, Front First Aid Kit, Ultimate Cup holder
    RIP: 2003 540iA Sport GS56111
    H&R front springs, Ultimate Cup Holder, Euro Dash & Armrest, Grom, BavSound Stage1
    Grove City, OH
    BMW Master Technician
    Video isn't the greatest, but sounds like top end noise until oil pressure builds up.... The M62 uses 2 anti-drainback valves to keep oil from daining out of the valvetrain and VANOS. Just to note, the timing chain tensioner also uses spring pressure to keep tension on the timing chains on startup, then oil pressure takes over. Check to see if your noise is coming from the front near the timing covers, or if it is coming from the top end.
    Mar 2019
    FL
    2001 BMW E38 740i
    I have had the same noise on startup since buying the car at 107k miles. I'm at 109k and recently changed the tensioner last month but the sound persists. I'm guessing it's as ulintze29 suggests about oil pressure.
    Feb 2019
    Nebraska
    '01 E38 '99 DINAN 5
    The chain guides, tensioner, and anti-drainback valves have all been replaced and the noise is still there. At times it's real loud and at times nothing at all, I'm confused and a bit scared something is coming apart. VANOS?? I hate to take it all apart again but if a VANOS rebuild will stop this dreaded rattle I'm all in! What do you all think?
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by DIEGOBMW View Post
    I would have guessed the valves behind the VANOS solenoid, but you are saying those were replaced. I dont think it's the VANOS units, they sound more like a diesel engine when going bad.
    On a positive note: nice valve covers!
    Feb 2019
    Nebraska
    '01 E38 '99 DINAN 5
    Would bad guides case this noise? The guides were replaced by the previous owner so I suppose there is always the possibility he lied to me.
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    There is nothing in this video what sounds too bad, but it's always hard to record noise properly. This helped me a lot for locating noises: https://www.amazon.com/Lisle-52750-S...s%2C114&sr=8-3
    Feb 2019
    Nebraska
    '01 E38 '99 DINAN 5
    I have one of those but the problem is the noise only last 1-2 seconds on startup. it's hit or miss on when it happens and to what severity. Doesn't matter hot or cold engine. All I know is my OCD is getting the best of me!
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Are you sure that those valves behind the solenoids were replaced or you rely on what the PO said? Cause that's still the best bet here.
    Jan 2006
    Ft. Lauderdale, FL
    98 740il, 00 540i,04 ZHP
    It's the vanos rattle on start up you hear. My 540i M62TU also has this rattle sometimes for 1-2 seconds on start up. The vanos is sometimes noisy and sometimes quiet when idling. I have replaced the check valves in there with no change (waste of money). The vanos likely needs a rebuild, but I'm probably not going to worry about it until I have to pull the valve covers or timing covers, or need to do guides.
    Feb 2019
    Nebraska
    '01 E38 '99 DINAN 5
    I did the anti-drainback valves and tensioner myself so I know they are new. The PO said he has the guides done so I hope so. If it's the VANOS making this noise and the diesel sound at hot idle then a VANOS rebuild is going to be done soon as it drives me nuts.
    Jan 2016
    Ca
    2001 525it
    No check engine light?
    Feb 2019
    Nebraska
    '01 E38 '99 DINAN 5
    Quote Originally Posted by jclausen View Post
    no check engine light?
    nope
  1. 95 m3 odd noise
    By AlexT in forum 1992 - 1999 M3 (E36)
    Last Post: 03-19-2001, 03:49 PM
  2. wierd noise from rear of car...
    By SJTrance in forum 1991 - 1999 (E36)
    Last Post: 03-15-2001, 11:42 PM
  3. Ticking noise after I shut off the engine
    By TD///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-04-2001, 02:54 AM
  4. clutch noise in neutral
    By Ian in forum 1992 - 1999 M3 (E36)
    Last Post: 03-03-2001, 01:49 PM
  5. Squeeling noise seems to have stopped??
    By Jim[UK]AKA 007 in forum 1991 - 1999 (E36)
    Last Post: 02-27-2001, 08:42 AM
