RM European Auto Parts
Results 1 to 3 of 3
Thread: P112F guestion for N55 F10
    May 2015
    Virginia
    2011 535i
    After getting reacquainted with this code, I have cleaned both MAP sensors, removed and cleaned the intercooler [very oily], and ensured that the oil filler cap is well sealed. A Google search revealed this simple suggestion from a 'CCA member:
    Couple things can cause this one, the start of the death of a high pressure fuel pump. Try this first unplug the tank vent valve and let the vehicle idle for 15 mins and plug it back and clear the faults. This will reset the DME adaptations and if the fault stays away its fixed. If it returns the high pressure fuel pump might be the issue and need to be looked into.
    Can idling for 15 minutes with the tank vent valve disconnected cause any harm? I assume that the potential upside is that this protocol will give the computer a new baseline from which to quantify the relationship between throttle position and boost pressure.
    Comments, suggestions, pithy wit?
    tia, dirtup
    May 2015
    Virginia
    2011 535i
    Fortunately, this turned out to be a false alarm: when removing covers to scope out the fuel tank vent, I discovered that the CCV hose had popped out of the intake tube just downstream of the MAF. Popped it back in [tightly this time!] - no more CEL.
    Wish they were all this easy,
    dirtup
    Jul 2004
    Houston, TX
    36 Cylinders
    Glad it's solved.
    Often you'll get a much better code and description if you use BMW oriented scanner that reads BMW codes. There can be many BMW specific codes assigned to one vague P code.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  1. f10 n55 flash tune
    By PortugeseF10N55 in forum 2011-2016 (F10)
    Last Post: 11-28-2020, 06:06 PM
  2. Replies: 8
    Last Post: 04-19-2019, 08:09 AM
  3. Replies: 0
    Last Post: 07-23-2016, 08:59 PM
  4. Burger Motorsports N55 Stage 1 Tuner (plug n play) and F10 N55 Intake
    By TMoNeE in forum Engines, Performance Parts & Software
    Last Post: 01-15-2016, 06:34 PM
  5. BMS F10 N55 Intake, Filter and Mounting Hardware - No Longer Available
    By Bimmerwpb in forum Engines, Performance Parts & Software
    Last Post: 12-18-2015, 08:15 AM
