Has anyone experienced a very slow battery drain of about 65-70 mA? I have been having battery drain issues for the past year or so and since I don't drive my car very often and can't throw a trickle charge on it every now and then since I park on the street my battery dies about 3 times a year. It is quite annoying, and I have tried pulling a few of the fuses to no avail. Granted I haven't done an all out investigation looking at every fuse. Any ideas y'all have would be helpful.
I have been having issues with my secondary air pump throwing codes, could that be the culprit?
The SAS circuit could be at fault if the relay is sticking or you have a short. Low on overall probability though.
Finding that drain is going to be fun as you are near target...
Do you have any aftermarket items installed?
2001 750iL DD74441
E65 fan & clutch, E65 headrests, Front First Aid Kit, Ultimate Cup holder
RIP: 2003 540iA Sport GS56111
H&R front springs, Ultimate Cup Holder, Euro Dash & Armrest, Grom, BavSound Stage1
I did have an aftermarket subwoofer and radar detector hardwire, but I checked the wire splice areas today and made sure they were insulated/taped up so I don't think those are causing issues.
Is that 65-70 ma measured after the car goes to sleep?
70mA sounds like a tracker is fitted somewhere - but is not the cause of your batteries going flat. You are just not putting enough charge into them due to your usage pattern. And once a battery has been flat for any length of time they are permanently damaged and should be replaced. More info here:
https://www.meeknet.co.uk/E38/E38_Battery_Drain.htm
My BMW Repair YouTube Channel
It's not a matter if the splice is ok, it's the mater of the bus system not liking the system tap, I would start by removing the aftermarket connections then see what happens also if the car is not going to sleep or being woken up the p park light. On the shifter plate will lift up.
Yep, this is measured after the car is asleep (16 min) per the meeknet protocol. I have removed all of the taps, but i could check the park light as you suggested. As far as charging, I agree, if I were driving the car regularily I probably wouldnt notice. I did recently replace the battery but that didn’t help much. Perhaps I just need to move to a place where I can set up the battery on a trickle charge when the car is sitting.
