RM European Auto Parts
Results 1 to 15 of 15
Thread: Rebuilding an M54
    Jul 2010
    KC, Mo
    04 M3, 02 E39, 01 46 M3T
    Rebuilding an M54
    I have built up at least 25 M or S 50s and 52, and some M20s. Never had a 54 apart.
    Here is what I need to know --- Given the aluminum block, I am certain that the cylinders are some sort of alloy as well. If one want to do new rings in an M54 that has good bores, can one simply clean the engine, soap and water the bores, and oil them -- on do they need to be lightly honed. IF SO, are special hones needed, and what would they be?
    NW suburban Chicago
    hiss by my window
    I believe it has cast iron cyl liners
    Jul 2010
    KC, Mo
    That is what I am trying determine.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Use a magnet.
    Jul 2010
    KC, Mo
    Quote Originally Posted by MarcoZandrini View Post
    Use a magnet.
    Ummm .... duh.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Hey, I’m trying to help! ;-)
    Jan 2016
    Ca
    2001 525it
    It's not lined it's coated with the alumisil stuff
    Jul 2010
    KC, Mo
    If so, how are they bored for oversized pistons?
    Jul 2010
    KC, Mo
    Just heard back from Karl @ Active Autowerke. Aluminum block, .060 thick steel lines, max overbore .050.
    MauiM3Mania's Avatar
    MauiM3Mania is online now Observer/Master Skeptic Moderator
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Quote Originally Posted by snaponbob View Post
    Whats the available sizes for pistons?
    88M3 AW 43k miles Project FS
    Jul 2010
    KC, Mo
    Jan 2016
    Ca
    2001 525it
    So how much does it cost to have the liners installed and are you rebuilding it to stock
    Jul 2010
    KC, Mo
    Quote Originally Posted by jclausen View Post
    Rebuilding to stock, but no intention of boring. Why new liners?
    BTW, I have purchased liners (for M52s) from melling. CHEAP !! But, they are straight, no lip. Also, not expensive to install and "fit". However, if one were to do all six, they would NEED a torque plate.
    NW suburban Chicago
    hiss by my window
    leaving a .010" cylinder wall??
    Jul 2010
    KC, Mo
    I know what I am told, and the person who told me is beyond reproach.
    Clarification .....
    The email stated the following
    "they use aluminum with a steel liner that is only like .060" so re-bore has to be minimal. I have rebored them from 84mm to 84.5mm, so basically take off .010" the wall thickness. Never seen issues."
    I mis-stated the dimensions previously.
  1. M54 Swap or Rebuild? Burns Oil.
    By starfox5194 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-22-2013, 08:12 AM
  2. Rebuilding an M54 325
    By snaponbob in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-20-2013, 08:07 PM
  3. E46 m54 Engine Needs Rebuild
    By Archero in forum Engines, Performance Parts & Software
    Last Post: 10-15-2012, 11:25 PM
  4. Question on pulling the M54 for a bottom end rebuild
    By Jackcat559 in forum Forced Induction
    Last Post: 04-05-2010, 07:56 PM
  5. complete M54 3.0 rebuild and ready to drop in.
    By bigugly in forum Engines, Performance Parts & Software
    Last Post: 12-08-2009, 09:43 PM
