RM European Auto Parts
Results 1 to 3 of 3
Thread: Mixture control, vacuum leaks
    Mar 2018
    Anthem, AZ
    2003 bmw 330ci 2001 bmw
    I have a 2001 x5 4.4i with the following codes with check engine light and strong gas fumes where should i start?
    1a mixture control, off idle cylinder #1-4
    1b mixture control, off idle cylinder #5-8
    1d mixture control, idle cylinder #5-8
    Bc dmtl large leak
    8d engine cooling fan control
    Jul 2004
    Houston, TX
    36 Cylinders
    Smoke test to identify all vacuum leaks (I bet there are many), inspection of fuel system for leaks, and check cooling fan for function.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    agreed.
    yup, i'd smoke test and test the evap system for functionality and leaks, and smoke test the intake as well.
    test cooling fan with a bi-directional scanner....
  1. Heat and A/C control vacuum leak fix DIY
    By gizwiz in forum 1978 - 1987 (E23)
    Last Post: 04-09-2017, 12:13 AM
  2. INPA code 32: Idle speed control = vacuum leaks?
    By Justin517 in forum 1996 - 2003 (E39)
    Last Post: 09-25-2012, 09:29 AM
  3. Installed new engine- Eratic Idle then Check engine. Vacuum Leak?
    By NAH325i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-25-2002, 08:33 AM
  4. Vacuum Leak.... or not?
    By Stockman in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-15-2002, 03:02 PM
  5. Vacuum leak?
    By JT-KGY in forum 1992 - 1999 M3 (E36)
    Last Post: 03-31-2001, 09:14 PM
